Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
steering wheel
Old Nov 23, 2008 | 07:10 PM
05civicdriver's Avatar
Default steering wheel
hey guys. i recently jsut got my winter tires on the car. and an alighment done to it. i noticed that the steering wheel is tilted towards the right and when i straighten the steering wheel the car drifts to the right. it does drive straight when its on the tilted position. is there anyway i can fix the steering wheel myself? i tried searchin for this topic but im not used to searching on this new honda-tech program.
thanx guys
Old Nov 23, 2008 | 07:22 PM
BakktoJDM's Avatar
hopefully where you got your alignment, like most places, has a warranty so go back and let them know and they should fix it
Old Nov 23, 2008 | 07:46 PM
ejLday's Avatar
sounds like the did not do a proper job of aligning your car. Take it back as soon as you can, you don't want to wait it out
Old Nov 23, 2008 | 08:07 PM
MagneMike33's Avatar
Yeah just take it back to have them fix it. It sounds like they didn't straighten the steering wheel when they did the alignment. You have to turn the steering wheel level when you do that and then lock it in place with a steering wheel tool that sits on the seat and holds the steering wheel in place. So just go back and have them redo that for you.
Old Nov 24, 2008 | 08:19 AM
daddy's Avatar
you can straighten the steering wheel by removing it and then properly clocking it.
you have to remove your airbag and then there is a 19mm nut that holds the steering wheel on.
i'd just have the alignment place fix it tho
Old Nov 25, 2008 | 06:01 PM
ejLday's Avatar
yea I would try getting it re-aligned before I adjust the steering wheel
Old Nov 26, 2008 | 07:30 PM
ok thanx guys, i called the shop said theyll work on the car to fix it.
Danielsb20crx
39
Jan 6, 2013 01:02 PM
b e e
Nov 19, 2004 11:04 PM
