dizzy
Old Nov 23, 2008 | 05:04 PM
dacrxguy's Avatar
Default dizzy
hey guys well my ignitor went out and i am planing on buying a new dizzy
i took the dizzy off to look for the part number but it was a remanufactured unit and the stamp has long dissapeard so im wondering if anyone knows the oem part number for a 91 crx dizzy
and i found this dizzy and am wondering if it is since both the hf and dx are 1.5 litters
http://cgi.ebay.com/ebaymotors/BRAND...QQcmdZViewItem
it is way cheaper than what my local autopart stores charge and i want to keep my old dizzy to rebuild it
Old Nov 23, 2008 | 07:29 PM
dacrxguy's Avatar
and one more ????? where is the service plug for timing on the 91 crx i tried the in cabin one and cant find the one in the engine bay
Old Nov 24, 2008 | 12:38 AM
Redline130's Avatar
What is your CRX, a DX or a HF? If it's a DX, then you can use that distributor. If it's a HF, you cannot.
Old Nov 24, 2008 | 05:32 AM
bobbymoon's Avatar
service plug is located on the drivers side toward the front of the wheel well with a yellow cover on the plug, the plug has two wires
Old Nov 24, 2008 | 08:10 AM
dacrxguy's Avatar
woops i forgot its a dx
i have nothing near my wheel whell will take another look
x2. See the OEM part numbers at www.bkhondaparts.com , under car model, engine, distributor.
Originally Posted by honda.lioness
OEM dizzy is the best way to go, but I realize one can buy four Distributor King dizzys for the price of one complete OEM dizzy. Reviews of DK are mixed though lean favorable, per
http://search.yahoo.com/search;_ylt=...&cop=&ei=UTF-8
It seems a good enough gamble.To me, the alternative is to find a decent junkyard dizzy, cannibalize the housing, clean the housing (the three engine control sensors get oily and dirty), install new, all OEM cap, rotor, igniter, and ignition coil, with new O-ring seal and shaft seal. This will run you about $200 total for parts.
thank really cleared stuff up for me as for your advice for piecing a dizzy together at a junkyard i will right now i am just going to go with the dk for a quick fix and it will be my backup dizzy as soon as i piece my junkyard dizzy together the reason i am not going to fix my old dizzy is that the bearings are shot there is alot of red dust in the shield inside the dizzy thanks for the input
Old Nov 25, 2008 | 11:10 AM
dacrxguy's Avatar
when u hook up the green/white wire with the brown one is the check engine light suposed to come on in my case it dint
Old Nov 29, 2008 | 02:36 PM
dacrxguy's Avatar
im trying to set timing but when i jump those wires nothing happens could be cause of my code 15 but my new dizzy should be here monday thanks for all the help honda.lioness
ZRose
Apr 4, 2008 08:15 PM
3RX
Oct 27, 2007 09:45 AM
CustomVW
Oct 10, 2005 06:18 PM
black00civicsi
16
Dec 11, 2004 11:59 AM
SHG_Beans
Nov 27, 2003 07:53 AM
