Help on my Viper 791xv on a 91 CRX!..please
Old Nov 23, 2008 | 04:48 PM
xJu1c3x's Avatar
Default Help on my Viper 791xv on a 91 CRX!..please
hey whatsup to everyone that reads this!
Car:91 honda crx HF
Alarm: Viper 791 xv, and NOT using remote start!
i wanted to know:
1. Do i REALLY need to wire up the heavy gauge "Relay Satellite"..cause ive heard that i dont need to, it was just for Remote Start,i also heard that i just need to connect the "yellow"(2nd pin) wire from the remote start ribbon cable, to the ignition cable on the car's harness and i can depin/cut the rest of the wires!
2. I will be using the Double guard sensor( the one that came with the alarm), DEI tilt sensor, and the DEI audio sensor( for glass shatter), so i wanted to know HOW and WHERE do i connect all my sensors...am i supposed to use diodes to separate the sensor's negative signnals
3. For the door triggers, on a 91 honda crx, on which door will it detect both door opening, the drivers or passengers, cause ive heard that the drivers door only detects 1 door!
4. hod do i hook up a "Domelight supervision" relay?
5. for the Parking light flash, i know that the crx sends a "+" signal, so do i need a relay do connect the parking lights?
6. do i really need to connect the "Tach wire"....im not going to be using remote start so is it still neccessary?
Old Nov 24, 2008 | 05:18 AM
fcm's Avatar
fcm
Old Fart
You do not need the "heavy gauge "Relay Satellite", you will need the yellow lead in the ribbon harness, connect to "true ign.". [hot in run and start].
On page 32 of the install guide it shows how to wire a second dual stage sensor along with the dual stage shock sensor, however both the tilt and audio sensors are single stage so I would connect them both, [along with the hood pin] to the hood pin input, [H3/4] and install diodes on the sensor trigger leads to isolate the sensors from each other, the hood pin does not need a diode.
Door trigger can be connected to the pass. door pin switch or the green/red running to the dome light, green/red can also be found behind drivers kick panel.
For DLS wire relay like this... http://www.the12volt.com/relays/page4.asp use the second one, [negative door trigger] and connect #30 to the same place as you connect the door trigger lead.
A relay is not needed for light flash, plug white lead into park light free pin on under dash fuse box.
No you do not need the tach lead, or any of the leads on the H3 harness except the hood pin trigger lead.94
Old Nov 24, 2008 | 10:37 AM
franckcrx's Avatar
Hi.
I have a Civic EF9 with Hornet Alarm.
fcm helped me a lot here :
https://honda-tech.com/forums/audio-security-video-27/hornet-563t-honda-civic-ef9-sir-1990-a-2433689/
and this helped me as well
https://honda-tech.com/forums/audio-security-video-27/%5Bhow-%5D-car-security-1794938/
Take care
Old Nov 24, 2008 | 01:22 PM
xJu1c3x's Avatar
Default thanks
thanks all you! ive read the links you gave me!
...also, do i need the H2 harness?.....its just for auxillary stuff like trunk popper, windows, etc.. right?? or what can i hook up to that harness? what is it for!..
and again for the sensors.... where do i splice them!...what wire..and which ones can i connect together and which ones cant i hookup together?
corect me if im wrong but the BROWN and ORAGNGE/BLACK wires are just for a channel 6 horn right...?..i DO NOT conect the alarm right?
Old Nov 24, 2008 | 11:59 PM
franckcrx's Avatar
on the second link, it says how to splice sensors. I did it this way.
The H2 harness, i do not use it on mine, as there is no factory alarm on mine (i guess on yours too)
On the second link as well, it tells you which wires you can put off before to start working on fitting it in the car ;-)
CrxChicken
Nov 16, 2012 08:37 PM
dubrider
Audio / Security / Video
Feb 18, 2009 02:50 PM
crxdigo
Jun 1, 2006 02:01 PM
Skitals
Apr 29, 2005 06:01 PM
MilanoRex
13
May 22, 2002 01:22 PM
