Brake Light Help!!!!!!!!
Old Nov 23, 2008 | 02:21 PM
Bonestock98GS's Avatar
Default Brake Light Help!!!!!!!!
Well I brought new bulbs for my CRX the other day figuring it was blown bulbs. I replaced them and I cant figure out why my brake lights arent working. Where should I start diagnosing the problem at first?
Old Nov 23, 2008 | 02:32 PM
EFRue57's Avatar
fuse?
Old Nov 23, 2008 | 03:20 PM
which fuse would it be?
Old Nov 23, 2008 | 03:49 PM
EFRue57's Avatar
the brake light / tail light fuse
Old Nov 23, 2008 | 03:51 PM
EFRue57's Avatar
if you don't have the underdash diagram on the fuse cover, then just pull 1 fuse at a time, checking to see if it is blown, and if not then put it back where it goes before moving to the next one. if you find one that is blown then replace it with the proper amp fuse and see if that fixes your problem.
Old Nov 23, 2008 | 03:57 PM
ok thanks for that I am going to do that right now. If I cant find one blown what do you think it could be after that?
Old Nov 23, 2008 | 07:14 PM
dacrxguy's Avatar
well the way i do it is with a test light u ground the test light and u touch the little metal part of the fuse on top with the test light probe if the test light lights up on both sides then its good save me a bunch of time
ps the key has to be on the 2nd position for some of the fuses to light
Old Nov 23, 2008 | 11:22 PM
Well ive checked all the fuses and they seem to all be ok even tried changing the fuse for the tail lights. I had a friend mention a brake switch. Where could I find that.?
Old Nov 24, 2008 | 12:34 AM
shirecain's Avatar
could be the brake switch on the peddle or some corrosion on the elec
Old Nov 24, 2008 | 07:06 AM
Corrosion on the elec? whats the elec?
Old Nov 24, 2008 | 07:13 AM
PISTONEMPIRE's Avatar
by elec I think he meant electrical wires.
Old Nov 24, 2008 | 07:38 AM
mugen92acintls's Avatar
the switch could very well not be makin contact. Also there are ground in the back if u take the covers down and plugs to remove the tail lights w/o takin the bulbs out. check that out that might be the prob
PS-- look under the hood for any fuses in the fuse block for the tailights
Old Nov 24, 2008 | 07:42 AM
I might have to check the wires to see if they have ground. My fuse box is under the dash. I have a B16 swap in the car also. I dont see a switch on the brake pedal so I am assuming thats the problem but im not ruling anything else out. I just hope its not wiring
Old Nov 24, 2008 | 11:09 AM
jdmed3's Avatar
by the sound of it its probably wiring... are your blinkers and reverse light working? your wiring harness might not work with your swap ive seen it happen before (crx hf w/ h2b swap)
Old Nov 24, 2008 | 12:46 PM
grog's Avatar
Are you sure? its above the pedal itself attached to a "tab" that lines up with #8 in the pic below
Old Nov 24, 2008 | 11:16 PM
Thanks Grog That Diagram was a life saver Buddy. And to JDMED3 yea my reverse lights and blinkers work. I just hope it isnt a wiring problem because I suck at wiring.
Old Nov 25, 2008 | 07:52 AM
jdmed3's Avatar
update on the issue?
Old Nov 25, 2008 | 06:45 PM
I didnt get a chance to check anythig out today but as soon as I do I will keep u updated JDMED3 tahnks for checking bro
w8n2crz
Apr 19, 2017 06:46 AM
NoSwapNoCare
Sep 28, 2006 12:47 PM
Bobby808
Apr 10, 2005 11:13 AM
therealitsjustme
May 31, 2004 08:04 PM
AutoboTxEK
Mar 9, 2002 09:46 PM
