is gt35r to big
Old Nov 23, 2008 | 12:52 PM
jdmlude87's Avatar
Default is gt35r to big
hey im turboin my 01 sh prelude stock internals but usein a sp ram horn turbo manifold and want to use a garret gt35r what do u guys think to big?
Old Nov 23, 2008 | 04:08 PM
ghostofnyc's Avatar
what is your goal
Old Nov 23, 2008 | 04:26 PM
JTCdudeman's Avatar
Master H Technician
Honestly, Its too big for a stock setup IMO. You would be better off with a GT30R. Having seen both turbos at work, the powerband from the 30 is much better feeling for less than 12psi. Coincedently, I doubt your going to be running more than 12psi on a stock setup.
Old Nov 23, 2008 | 05:09 PM
Redprelude98's Avatar
i have talked to a couple of racing places around the city and they have told me that the most boost i could push on a stock internal h22 is 7-8 psi at most
Old Nov 24, 2008 | 06:00 AM
jdmlude87's Avatar
i new that i just dont want lot of lag but wanna pull hard as well does that make any sense?lol
Old Nov 24, 2008 | 06:18 AM
vinuneuro's Avatar
Too many people on this site choose turbo's that are just way too big for a street car. Do some research, choose the right size, and the result will be a setup that has both good response and makes good power.
Read through all the article on this site. For reference, the volumetric efficiency of the H22 is 102%.
http://www.turbobygarrett.com/turbob...ch_center.html
Old Nov 24, 2008 | 06:19 AM
vinuneuro's Avatar
Psi is an arbitrary figure that doesn't mean anything out of the context of turbo size. On a stock motor, hp and tuning are the important factors.
Old Nov 24, 2008 | 06:37 AM
jdmlude87's Avatar
k im hinda lost
Old Nov 24, 2008 | 06:43 AM
vinuneuro's Avatar
Originally Posted by jdmlude87
k im hinda lost
Did you go through the link in the post above that one. x psi from one size turbo will result in vastly different amount of air flow v. a different size turbo and the same psi.
Old Nov 24, 2008 | 07:47 AM
Pman92's Avatar
what he is telling u is psi has no relation to how much power ur going to make. 6-7psi on a gt 30 compared to a gt 35 is going to net u 2 different horsepower ranges. You need to deside on how much power u would like to achieve then go for the turbo thats going to get you there for least amount of exspense. 35r is way to much for a stock application unless your planning on going full blown build later. 30r would work fine for now and later even if your looking foor a 400whp setup. Or go the little bit cheaper route and run a 60-1 for 700.00 and its good for up to 550whp on a built set up. tuneing is the key to keeping your engine together.
Old Nov 24, 2008 | 02:59 PM
jdmlude87's Avatar
so ur saying the 30r can give me 400 hp at 7 psi with out build im down for sure
Old Nov 24, 2008 | 03:22 PM
ProjectBB6's Avatar
rofl... 400whp at 7psi? naw... more like 280whp.
Old Nov 24, 2008 | 03:45 PM
mattsnooz's Avatar
jesus, I like his math. 7 psi = 400whp. so why did my 6 psi (5.5 at the IM) only come out to 242 whp ??? lol. Must be in my ghetto tune. I'll take that on my stock h23 with my crome tune anyday though hahahah.
Old Nov 24, 2008 | 04:47 PM
jdmlude87's Avatar
ok i didnt understand him but no need for the smartness plus i herd crome sucks and u have a h23 less hp
Old Nov 24, 2008 | 05:35 PM
BlacktraxGirl's Avatar
gt35r is not efficient on stock motor for daily.... do a little more research into exactly what youre trying to accomplish power wise and get a turbo thats sized right for your goals/driving style/budget
Old Nov 24, 2008 | 06:02 PM
jdmlude87's Avatar
i want to eventually rebuild so i wouldnt mind going with the 30r either so eveyone sayin go with the 30r ? or what
Old Nov 24, 2008 | 06:18 PM
crazyz250's Avatar
go with a 30r i have it on my 99sh been at 10lbs all summer runs perfect that 35r would lag more then you would want. What size injectors? FMIC? wastegate? exhaust? have you figured any of that out yett or jsut think a turbo sounds cool rite about now?
Old Nov 24, 2008 | 06:41 PM
^^ exactly what i meant when saying decide on a plan then pick the turbo. theres so many other things to factor in before you settle on the turbo itself.
gt3071 or the gt30/40
the 3071 will allow for a little more low end boost. we use that one on our roadrace and daily 300-500whp cars.
when do you want boost to kick in? how long do you want it to last? if you want a nice low end daily car then i suggest something simple like a disco potato room to grow would be the 3071.
i have a gt35r for my engine that im shooting for all top end 600+whp....it wont spool until 5k idealy but will climb thru to redline.
when you rebuild for more boost its about doing all the calculations again....but the 3071 will give you room to grow....you can also upgrade the cartridges later on if you have a big enuff housing. AR plays its part in spool and power also...so yeah...like i said..theres a lot of things to keep in mind when picking your turbo.
Old Nov 24, 2008 | 07:26 PM
98vtec's Avatar
moderator emeritus
my opinion:
start small and then work your way up to the big boys and acquire knowledge along the way. Its pretty obvious that you just want a fast car and you have no clue what you are doing (no offense), but do you have the ability and knowledge to keep such a motor maintained and running properly? Then think about how unstreetable a high horsepower car is in reality driving it day to day. Daily driving, you are not going to want to sacrifice throttle response in the event you have to pull into traffic. Another very good idea is to install PWM boost control and have a good engine management which can control boost by gear so you dont have to run full boost in all the gears and sacrifice traction.
Old Nov 24, 2008 | 07:49 PM
jdmlude87's Avatar
do u have stock internals i want the sp ram horn manifold with 3" exhaust, i was going to get a 39mm tial wastegate and a 27x7.5x3 percision intercooler and mabe 550cc delp injectors
Old Nov 24, 2008 | 07:53 PM
teefunk01's Avatar
I think a 35r is perfect turbo for a h motor
Old Nov 24, 2008 | 07:55 PM
jdmlude87's Avatar
Originally Posted by 98vtec
my opinion:
i was going to run a p28 w/ hondata s300 and i dont drive my car every day i just track it or cruz with my boys on the weekend i got an every day car
Old Nov 25, 2008 | 11:58 PM
iLuvMyJDMeg6's Avatar
i ran a gt30r on my stock h22 and made 427 @ 14lbs, i also have a gt30r and 38mm tial wastegate for sale if your interested. pm me if your interested and good luck on the build
Old Nov 26, 2008 | 10:41 PM
97shlewd's Avatar
instead of putting that money into the turbo maybe building the motor or buying another motor and build that. just an idea
Old Nov 26, 2008 | 11:42 PM
HondaKyle's Avatar
A waste of money for what you have...
