Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
What Class would I be in auto cross...?
Old Aug 1, 2002 | 03:20 AM
Turtle's Avatar
Default What Class would I be in auto cross...?
If I had a Type-R,
and had bolt-ons, (mugen twinloop, header, cat)
Cams, (Toda A's) and Cam gears.
Could I still enter CSP?
Old Aug 1, 2002 | 03:27 AM
Crosser's Avatar
Default Re: What Class would I be in auto cross...? (401-2001)
No, the cams and cam gears bump you into Street Mod. Get ride of them and you can run STX with street tires, or CSP with R compounds.
[Modified by Crosser, 4:28 AM 8/1/2002]
Old Aug 1, 2002 | 06:00 AM
Turtle's Avatar
Default Re: What Class would I be in auto cross...? (Crosser)
So what if I didnt get the cams, but kept the cam gears (since they are currently on the car)? I am assuming I would still be in Street Mod?
Old Aug 1, 2002 | 06:14 AM
Crosser's Avatar
to be 100% legal, yes, you would be in street mod, however, on the local level, and expeically if you are new you could run STX and no one would really get too bent about it. If you start winning though, rightfully, you should change back to the stock cam gears.
Old Aug 1, 2002 | 06:21 AM
Turtle's Avatar
Thanks for your help...one last one...no cams, no cam gears, what if I had an ATS Final Drive. What then...cause there would be no engine mods. Again thanks Crosser.
Old Aug 1, 2002 | 07:12 AM
fastfour's Avatar
Basically (for the most part) if you crack something open and replace it with something that wasn't there originally, you'll be in SM.
Old Aug 1, 2002 | 07:22 AM
CivicSiRacer's Avatar
Default Re: What Class would I be in auto cross...? (fastfour)
STS/STX allows no internal engine mods or tranny mods except in short shifters. STX if I remember right allows clutches. But don't quote me on that one.
Old Aug 1, 2002 | 07:27 AM
Todd00's Avatar
I said I don't want a title!
Default Re: What Class would I be in auto cross...? (CivicSiRacer)
nope, no clutches in STX.
Old Aug 1, 2002 | 07:56 AM
Crosser's Avatar
take a look here http://www.moutons.org/sccasolo/
It does not have STX, but you can just assume anything you can do for STS you can do for STX.
Old Aug 1, 2002 | 08:49 AM
And then also add:
motor mounts
catalytic converters within 6" of the original unit
wider wheels
wider tires
and non-reclining seats
Old Aug 1, 2002 | 08:57 AM
Todd00's Avatar
Seats still need to recline in STX AFAIK.
Old Aug 1, 2002 | 09:13 AM
vwong's Avatar
Default Re: What Class would I be in auto cross...? (Todd00)
Nope, you can have a non-reclinable seat in STX, but the construction of the seat must not be Kevlar (the lightweight stuffs). Therefore, it cannot serve as a purpose of reducing weight.
Old Aug 1, 2002 | 09:47 AM
Todd00's Avatar
Default Re: What Class would I be in auto cross...? (vwong)
I never understood the STX seat rule. I asked at the beginning of this year if non-reclinable seats were allowed and I got a big no on that one. Specifically, this one:
http://www.sparcousa.com/pseats_street.asp?id=97
here's the rule:
Alternate driver and front passenger seats are allowed, but they cannot be constructed of a solid outer shell and must have a suspended bottom cushion and be fully upholstered.
Solid outer shell is what throws me.
Old Aug 1, 2002 | 10:18 AM
vwong's Avatar
here's the rule:
Solid outer shell is like those made out of Kevlar and Fiberglass construction shells. Something like this would be ok, http://www.sparcousa.com/pseats_competition.asp?id=93.
But now that I'm reading the rule again, I don't think this seat is legal either 'cuz of the "suspended bottom cushion".
I'm hoping that SCCA will allow full racing bucket seats in STS/STX class 'cuz then I could get the seat I want.
Old Aug 1, 2002 | 06:21 PM
jasyatz's Avatar
The Sparco and Sprint style seats are fixed back and suspended bottoms. They are a tubular steel frame with a padded lower cushion and removable cover...Cost about $200 each and weight about 22lbs a piece...
That's the reason they are allowed, by the time you add brackets and hardware, only save about 5lbs off a stock reclinable seat. (Speaking Civic here) Del Sol seats are about the same weight each (approx 30-32lbs each)
Jeff
da_all_day
May 29, 2011 09:45 AM
sgnlab
Aug 31, 2010 05:11 PM
st3alth
May 26, 2005 07:39 AM
MDintegra95
May 5, 2005 08:28 AM
CBR600OnTop
Jan 28, 2003 08:42 PM
