NSX... best tires?
Old Nov 23, 2008 | 08:04 AM
NSXRguy's Avatar
Default NSX... best tires?
im "most likely" will be picking up 18/19 work meisters to replace my 17/18 hre 540 setup
im looking for the best band for buck summer tires which will also see some wet days
what brands to stay away from?
Old Nov 23, 2008 | 01:09 PM
nsxtasy's Avatar
H-T Order of Merit
Tire availability for 18"/19" wheels is very skimpy, compared with the many tires available for 17"/18" wheels. The 18"/19" sizes you'll need are 215/35-18 and 275/30-19. The only really good summer tire available in those sizes is the Pirelli PZero Nero. You can get less expensive tires, but they will be a significant step down in performance, and there's no sense in degrading the performance of your supercar in order to save a few bucks on tires.
Old Nov 26, 2008 | 12:08 PM
NSXRguy's Avatar
i have pirelli pzero nero m+s right now on my 17/18
im thinking about either going with
toyo t1r
pirelli pzero nero
nitto nt555
Old Nov 26, 2008 | 03:50 PM
nsxtasy's Avatar
H-T Order of Merit
Those are all-season tires. Do you drive your NSX in the winter? If so, then all-seasons are probably a good idea, although they will compromise your performance the rest of the year. If not, then you can take advantage of the higher performance of summer tires.
toyo t1r
pirelli pzero nero
nitto nt555
Those are all summer tires, and the Pirelli is the best (by far). As previously mentioned, it's available in 215/35-18 for the front; you can use either 265/30-19 or 275/30-19 in the rear, and I know the PZero Nero is available in one of those sizes if not both.
Dyce
Dec 15, 2011 12:45 PM
square_1
Sep 26, 2010 08:55 AM
Heinekim
Feb 3, 2007 06:46 AM
cheaphonda
Jul 12, 2005 12:09 PM
garados
Jul 16, 2002 06:11 AM
