93 Si auto trans problems
Old Nov 23, 2008 | 06:42 AM
mugen92acintls's Avatar
Default 93 Si auto trans problems
I have a 93' Prelude si auto matic to drivecuzmy civic is getting to the point that its rough to drive on the roads. I notice once it got a little cooler out (PA) it wouldn't engage d3 or d4 until either it warmed up or if u stopped and put in park and back into d4, then it would be fine. Our first cold cold day (30 degrees) I noticed the damn thing was making a grinding noise every time I let off the gas in D4. The fluid was fine and it gradually got worse until D4 completly went out then reverse started not engaging. Now I have no D4 but I can get reverse, Its hard to drive in D3 because ofthe gearing (you will be tachen 5grand@ 60mph).
could this have something to do w/ the tcm (tran, control, module) or a servo. Someone said to me that their accord did the same thing and it was a burnt resistor in the TCM. if anyone got any info please let me know. I've been drivin my civic and since my dads Vigor bent the valves and we are replacing the motor my mom has to ride in my civic and its too rough on her cause my dads using her accord to commute to work. help me PLEASE!
Old Nov 23, 2008 | 08:06 AM
anyone have this problem before? don't reply with search, thats f**kn worthless to me
Old Nov 23, 2008 | 08:29 AM
Pullig's Avatar
i got a si auto trans i can let go cheap if you need
Old Nov 23, 2008 | 08:40 AM
how many miles on it i may be interested in that, I was thinking about converting it to a 5-speed. I got the pedal cluster and the hydrolines, master and slave, no 5-speed though. The motor in it burns oil like crazy I got another motos w/102,000 and I'm probably gonna change every thing at once. I toss the idea around with my dad and let you know, knowing him he'll want. I'll get back to you on htat thanks buddy
Old Nov 23, 2008 | 07:57 PM
Pullig's Avatar
well it came from my friends car that he wrecked ... i pullled it out along with the h23 motor ... i belive it had 60-70k miles but he said it was fine and shifted good still... but still would let go cheap cause i want this thin gone
Old Nov 24, 2008 | 06:38 AM
k still might be interested my parts guy has one he drove and and it shifted perfect and no slippage for $200.00. If the miles are to high I will most likly opt for the one ur buddy got. thanks man ill keep u postd
Old Nov 24, 2008 | 07:10 PM
Kronn 98SH's Avatar
Is swapping to a manual transmission out of the question? If so, be sure to check eBay and Craigslist.
Old May 25, 2009 | 12:08 PM
CRXDRU's Avatar
Default Re: 93 Si auto trans problems
im haveing a prob with a auto trans but i cant figure it out... mine works just fine till the car heats up then stops pulling... you can cut it off for like 3to 5 mins then start it up and it pulls again till it heats up again. idk whats up
HondaOfTheSun
Jun 20, 2015 08:08 PM
Gaoxiang Chen
Aug 12, 2012 04:17 PM
wvfarmboy
Jul 6, 2008 03:04 PM
idreamHonda
Jan 20, 2006 11:30 AM
opticonx
Jul 19, 2004 06:01 PM
