axle question
Old Nov 23, 2008 | 05:23 AM
JJ's civic's Avatar
Default axle question
so i have a si tranny and a 1990 std i don't think i can use my 1990 stock axles can i and if not can i use new hubs from an eg and eg alxes? and use that as an epgraded brakes in the front??
Old Nov 23, 2008 | 06:04 AM
Mr.Death's Avatar
Run on sentence. Grammar owns you. The drive shafts should fit.
Old Nov 23, 2008 | 09:59 AM
Redline130's Avatar
Your STD has different hubs from DX/Si models, thus the reason for your STD axles not working. You will need to use DX or Si hubs to use your axles.
Old Nov 23, 2008 | 10:22 PM
JJ's civic's Avatar
kool but can i use hubs from an eg?
Old Nov 23, 2008 | 10:30 PM
shirecain's Avatar
ok heres the deal. all si and 90 and on integra axles are the same spline on the hud side,period. they will fit all 88-91 4 door, crx, hatch as long as its not a 4 speed shell,period. if you do have the 4 speed shell then you should go with 90-93 integra front and rear spindles. i have done dozens of swaps like this. good luck
Old Nov 23, 2008 | 10:37 PM
shirecain's Avatar
Default wrong
this is wrong, all std dx lx ex si even auto axles are the same spline on the hub the only thing that will not work with the rest are the 4 speed manual axles. ive used auto axles from 91 integra into a 5 speed std crx. good luck
Old Nov 23, 2008 | 11:05 PM
thorclark's Avatar
Use hubs from a da
Old Nov 23, 2008 | 11:46 PM
D16SiHatch's Avatar
i think there is a "fairly" high possibility at some point in your cars life that someone swapped out your hubs then. std and hf hubs will not work with b-series axles. dx, si, or da hubs are his options if he wants to use the Si trans.
Old Nov 23, 2008 | 11:47 PM
Redline130's Avatar
I thought all STD models were 4 speed. Maybe I got confused with HF's. BTW, what is a STD CRX? I believe the only trim levels were DX, HF, and Si.
Old Nov 23, 2008 | 11:57 PM
D16SiHatch's Avatar
man i must be half asleep i didn't even catch that. yea i also would have to agree there is no crx std model. just civic std. so most likely his car is actually a dx, which would explain why the integra axles worked fine.
xTimmyx
Jul 12, 2012 11:50 AM
shoebox
Mar 16, 2009 07:59 AM
LurkerS8
17
Jun 25, 2005 07:46 AM
1CiViC1
May 29, 2003 03:54 PM
carsaregood
Feb 5, 2002 09:05 PM
