wiring harness question 91 CRX Si
Old Nov 22, 2008 | 07:56 PM
str8drift's Avatar
Default wiring harness question 91 CRX Si
Just bought a shell with no wiring harness... from dash to engine bay. can i use any crx wiring harness? if not. what applications will work? thanks guys.
Old Nov 22, 2008 | 07:57 PM
EFRue57's Avatar
90-91 crx si
Old Nov 22, 2008 | 08:34 PM
D16SiHatch's Avatar
i mean you could use a dx harnes but....... why would you want to lol. use the si harness so you'll be good to go for a mpfi engine. be it the stock d16a6 or somethin else.
Old Nov 23, 2008 | 06:26 AM
EFRue57's Avatar
no you couldn't. the dx is dpfi and the si is mpfi. there is a difference in the body harness.
Old Nov 23, 2008 | 06:48 AM
dabrat8614's Avatar
yes there is a difference the plug on the driver side shock towers are diff. you have to use a 90-91 si harness like someone said above
Old Nov 23, 2008 | 12:53 PM
str8drift's Avatar
thanks guys... really appreciate the feed back. 90-91 si harness it is.
Old Nov 23, 2008 | 05:32 PM
D16SiHatch's Avatar
no *hit there is sherlock. if you take notice he said there is not a harness in the car, be it engine or cabin. i was only saying that if he felt inclinded do so he could use a dx harness, as in the the complete engine and cabin harness. Of course this would not be adviseable because who wants to run dpfi, or have to convert to mpfi later down the line. Of course i was only giving him options, not questioning his motives. 90-91 Si engine/cabin harness is the way to go.
If you read what he said you would have made a note that there is no harness in the car. no harness means no shock tower plugs. an Si harness won't do him any good either if there is no cabin harness to connect it to
Old Nov 24, 2008 | 12:47 AM
shirecain's Avatar
dabrat cant read clearly and should pay more attention to the subject
91 si it is unless you want obd1 now is the perfect time to do the whole car harness swap
Old Nov 24, 2008 | 05:43 PM
str8drift's Avatar
to do a obd1 harness.. what car should i get it from?
Old Nov 24, 2008 | 05:49 PM
0ne-Cam's Avatar
theres no need to go obd1 unless u want to tune something, thats why obd1 is better but in his case, im assuming, he just needs a DD so get your self the complete harness out of 90-91 civic si
Old Nov 24, 2008 | 06:58 PM
EFRue57's Avatar
no *hit there is sherlock. if you take notice he said there is not a harness in the car, be it engine or cabin. i was only saying that if he felt inclinded do so he could use a dx harness, as in the the complete engine and cabin harness. Of course this would not be adviseable because who wants to run dpfi, or have to convert to mpfi later down the line. Of course i was only giving him options, not questioning his motives. 90-91 Si engine/cabin harness is the way to go.)
wow, you really got your butt hurt over that didn't you. now if you would take notice, no where did he state that the entire harness from the car was missing. only the harness from the dash to the engine bay. i assumed he had the engine harness, maybe the wrong assumption to make, but i was going only by what was in the original post.
but let me ask you this watson, why would anyone convert a mpfi car to a dpfi car?
Old Nov 24, 2008 | 07:20 PM
D16SiHatch's Avatar
By saying he bought a shell and no harness "from dash to enginebay" leads me to believe there is nothing in the car. you generally don't find engine harnesses still attached to shells without an engine..
He wouldn't be converting a mpfi car to dpfi. It's nothing at this point, the wiring is entirely absent. It is not up to me to figure out his motives. i'm simply giving him options and some are better than others. for example perhaps he has a complete dx harness which would cost him next to nothing to use, and be cheaper than sourcing out an Si harness. I mean i've seen people do weirder things. i don't recommend using the dx harness but its not like it wouldn't work.
Old Nov 25, 2008 | 08:58 PM
str8drift's Avatar
so if i did want to convert to obd1... where would i get the harness from?
Old Nov 25, 2008 | 09:52 PM
sgallagher's Avatar
You would use the 90-91 harness still. You would need an obd1 distributor, 4 wire o2 sensor and ECU. Get a jumper harness to convert (at the ECU) from obd0-obd1. Wire in the o2 sensor and dist and BAAM....OBD1.
BigbamaBen
Nov 6, 2011 01:50 PM
Suck my DX
Sep 7, 2005 10:58 PM
Suck my DX
Sep 7, 2005 06:32 AM
Suck my DX
Sep 6, 2005 07:27 PM
