99 wont start...not getting spark. HELP!
Old Nov 22, 2008 | 07:50 PM
vtecpower3088's Avatar
Default 99 wont start...not getting spark. HELP!
my 99 ex f23a1 wont start. it cranks but im not getting spark at all from the wires. The cap and rotor and wires and plugs are all brand new so i know its not that. also when i first pulled the wires off the plugs, all the spark plug tube wells were filled to the top with oil. there is no antifreeze mixing with the oil at all so i dont think its a headgasket. does anybody have any ideas??? PLEASE HELP
Old Nov 23, 2008 | 07:07 AM
hondadude's Avatar
Replace the valve cover gasket and spark plug tube seals.
Get the oil out of the plug wells.
To start the diagnose of no spark;
Check the Black/yellow wire at the distributor connector for power with the key on.
Power comes from Fuse #6 /15amp under dash fuse panel.
Then back to terminal#1 Black/yellow wire of the ignition switch.
Old Nov 23, 2008 | 05:50 PM
crazy thing happened today..i work at autozone and we use Actron OBDII scanners for our customers. My buddy plugged it into his car and now his car is doing the same thing mine did so the diagnosis is that Actron scanner is wiping out everybody's ECU. we hooked my managers car up on video and it wiped his out too. crazy stuff....i guess actron is buying me a new ECU and possibly a new engine
Old Nov 23, 2008 | 06:06 PM
YeuEmMaiMai's Avatar
lawl........replacing the gasket and tube seals will resolve your oil leak problem and most likely allow you to get spark
Old Nov 23, 2008 | 06:11 PM
impound's Avatar
call your local dealer and give them your vin. those accords have an ignition recall. if that car has not had it done its worth a shot....besides its free
oli1973
Mar 26, 2014 07:02 PM
adamt12
Feb 26, 2013 05:55 AM
Civic Hybrid
10
Aug 17, 2008 09:35 AM
2000h22a
Aug 4, 2008 12:48 PM
MikeTV
Feb 14, 2004 10:17 PM
