Locating oil leak
My 94 EX has an oil leak that i need to find and fix
I changed the oil today, and while under the car i really couldn't see where it is originating from because of all the dirt and grime for the years it's been around! Would it be a wise idea to spray the underside of the engine with a degreaser and hose it down to get it clean with hope of seeing where the leak is coming from or is there a better way to go about finding it
That's the first thing I'd do.
Clean it until everythings dry, road test it and inspect it again.
Either that or buy some petroleum based floresant dye, add it to the oil and borrow a black light from the local night club.
The dye will glow when the ultraviolet light hits it.
P
P
i am going to try to look into it more in depth today, but it is a pretty bad leak
i have to get this fixed as its my daily and i can't afford to have it break!!! thanks for the info fellas!!
If you find this in the vicinity of the oil filter (Engine (left side rear), the oil pressure sender switch (mounted just above the oil filter may be leaking. Both being under pressure, these both have the tendency to leak with some enthusiasm.
P
P
I changed the oil today, and while under the car i really couldn't see where it is originating from because of all the dirt and grime for the years it's been around! Would it be a wise idea to spray the underside of the engine with a degreaser and hose it down to get it clean with hope of seeing where the leak is coming from or is there a better way to go about finding itTrending Topics
immalooser
Sep 25, 2009 08:05 AM
Smokeeey420
Sep 26, 2006 09:08 AM
