Hard to get in gear sometimes
i got a eg civic with a gsr swap
trasn was rebuilt wit carbon syncos and quaife lsd new throwout bearing
clutch is like 6 months old comp stage 4 6 puck sprung
new slave cylinder
new master cylinder
the car was fine till like 2 days ago
sometimes like 8 out 10 times its hard to get in gear, if i put the car in gear and start it it like jumps like its engaged, its like kinda sometimes makes it grind if it dont wanna go in gear i just changed the slave cylinder today and still the same and my clutch pedal kinda squeeks at the top in the pedal play area
anyone know what could be wrong?
broke presure plate?
broke disc?
help please
new slave cylinder
new master cylinder
broke disc?
help please
What kind of clutch setup are you using? Did you replace the throw-out bearing?
I was gonna say possible bad clutch master cylinder, but i see you've replaced that.. You don't see any fluid leaking around the clutch pedal area do you?
If not.. then my guess would be your clutch disc or pressure plate is defective/broken.
yea i have a comp stage 4 clutch 6 puck sprung i put a new throw out bearing in wheni put the clutch in 6 months ago
but i just put the trans in like last week and put a new throw out bearing on then
i put a new slave cylinder on today so it was bled and still the same
