D16Z6 mini-me Distributor problem
Old Nov 21, 2008 | 05:32 PM
jawsiiv's Avatar
Default D16Z6 mini-me Distributor problem
Hey folks,
I am in the midst of a swap. I have everything taken off now I am about to put the new head on. I try to put the distributor on the new head, but for some reason it will not go in. I line up the notches, and the holes for the bolts, but when I push it in, it will not go in without some force. I know it is the right one because I have the right serial numbers. Any help is greatly appreciated, as I need to finish this before Saturday Night.
Old Nov 21, 2008 | 05:37 PM
94EG8's Avatar
Seagull Management
Did you try turning the 2 pronged cam in the end of the distributor 180 degrees? Its offset so it will only go in one way unless you really force it.
Old Nov 21, 2008 | 05:40 PM
jawsiiv's Avatar
I will try that right now to see if it works.
Old Nov 21, 2008 | 05:43 PM
jawsiiv's Avatar
94EG8 YOU ROCK. It worked. Thanks
95civicLS
May 5, 2010 08:13 AM
harley06
Oct 31, 2006 02:30 PM
dmcclain
Aug 10, 2006 05:21 AM
HarryB
Aug 13, 2002 09:13 AM
