crank questions
Old Nov 21, 2008 | 04:34 PM
915hondajunkee's Avatar
Icon6 crank questions
I tore up my crank and spun two bearings in my gsr. mains good and rod bearing ok' will replace all bearings. my question is ' can i use a ls crank in my gsr? and if yes what rods do i use ? ls rods or gsr rods? any help would be greatly appreciated!!!!!!!!!!! i have a new gasket set piston rings bearing rod bolts and head bolts and a good Ls crank. will it work?
Old Nov 23, 2008 | 09:59 PM
B18c1vicrx's Avatar
to make the ls crank work in the gsr block you'll need ls rods, as far is the piston rings and such go, i figure they should work but im not certain so i'd definetly do more research on that part
Old Nov 23, 2008 | 11:44 PM
shirecain's Avatar
good question, i think all b series parts are interchangable even rods, pistons, cranks all work together you just have to pick the right combo for the best performance, i think ls rods with p30 pistons would be the best for all motor
Old Nov 24, 2008 | 08:37 AM
B18c1vicrx's Avatar
well they they will work together but the issue is if you have an ls crank with gsr rods, the piston head would be slapping your valves and head since the gsr rods are longer and the crank has slightly different measurements too...the best thing to do is your own research so you don't just take the first words you hear into consideration
Mfoehrkolb
Nov 21, 2007 05:37 PM
ItsSlow
May 30, 2006 05:54 PM
J-Spec EG
11
Oct 30, 2004 09:14 AM
svmnredracr
Sep 28, 2004 07:46 AM
RTW DC2R
Apr 24, 2004 10:39 AM
