M/C to prop valve, which line went where?
i did a search, and couldnt find much... my story is i removed abs from my rhd eg6, and cant find oem lines.
the prop valve is the same, but the lines from the m/c to the prop are different.
also, the lines from the prop to the front 2 wheels are different.
so, its been awhile since i took everything apart, and cant remember what went where.
here is a picture
the port on the m/c (closer to the booster) goes to the top or bottom port on the prop valve?
and after this is all said and done, is there a special procedure to bleeding the brakes? or is it the same
here is a picture
Xscort
Feb 15, 2009 11:59 AM
BanEL
Nov 21, 2008 04:47 PM
Da1spaz247
Dec 11, 2007 06:28 PM
yaoming315
Feb 25, 2007 03:34 PM
