Technical question on Tach Signal - 93 Lude
Old Nov 21, 2008 | 02:46 PM
duanes's Avatar
Default Technical question on Tach Signal - 93 Lude
What type of signal is the "maintenance" tach connection on the passenger side wheel well of a 93 'Lude? Is this a PWM, a/c pulse, d/c pulse, % duty cycle?
I thought it would be a dc frequency, but my Fluke doesn't get anything. If I use ac frequency, I am getting 350-450, but engine is not idling that slowly. Dash tach shows 800.
Old Nov 21, 2008 | 04:16 PM
Giant_Bean's Avatar
my actron reads it just fine, but it has a tach setting, and also has selections for 4,6,or 8 cyl engines.
Old Nov 21, 2008 | 05:54 PM
ShoofIsLudin's Avatar
u need the tach adapter for ur multimeter. Some have a built in feature, some don't.
Old Nov 22, 2008 | 07:41 PM
duanes's Avatar
Hmmm - You are right - I recall that most tachs have to set the number of cylinders..... So, is this a pulse per spark?
I may have found a description - the signal should be a 12v square wave with one pulse for each cylinder per rev.
I need to try my meter again. - I think I just need to take the frequency and divide by four.
A.D.D. Racer
May 24, 2006 09:02 AM
Sketch_hs
May 12, 2003 07:11 PM
nkSi
Oct 3, 2001 05:39 PM
