Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Cooling from Koyo, JVT, Mishimoto on sale now
Old Nov 21, 2008 | 02:43 PM
Honda Gen's Avatar
Default Cooling from Koyo, JVT, Mishimoto on sale now
Fluidyne Radiators are constructed of light weight high quality aluminum. Each Fluidyne radiator is hand welded. If you compared the weld on a Fluidyne to other brand you can tell the high quality craftsmanship . One major problem with aftermarket radiators is leaking from the outlet to the overflow reservoir. Fluidyne use specially designed brass fittings and ensure a 100% leak proof radiator. All of our radiators are pressure tested, notice the billet aluminum fill neck is unlike any other radiator.
Fluidyne Aluminum radiators generally dissipate heat 20-25% better than standard OEM radiators. Whenever running an aftermarket setup or any high performance engine, one of the first replacements should be your radiator. No matter if it’s your daily driver or Track car upgrading your radiator should be the first thing you should do. The more power your engine makes that more heat it produces so installing a Fluidyne radiator is your answer.
Each Fluidyne Radiator Improve 20-25 percent over standard OEM Radiators
Each Fluidyne is Hand weld with quality Craftsmanship
Manual transmission Only
Koyo Radiators are uniquely designed to extract maximum performance out of high-revving, high-performance engines. The cooling power of Koyo Radiators can easily exceed the power of other radiators by 20% - 30%. Designed and manufactured to meet OE specifications, the Koyo radiators are molded in designs and specifications to suit different vehicle engines. Each part is individualized to meet the specific requirements of specific vehicles. Koyo Radiators feature aircraft quality aluminum, constructed with Heli-Arc welding, which is the highest quality standard for enforcement on aluminum connections. Also available in plastic tank version, these radiators are ideal for Turbo Charged, Super Charged and Nitrous Oxide applications.
Each Koyo Racing Radiator are polished finish.
Koyo Radiator Provide 20% to 30% more cooling than OEM Radiator
Great for Perfomance and turbocharged engines
Each Koyo Radiators made from aircraft quality aluminum best in the industry
Heli-arc welded, cores are NOCOLOK-brazed with Koyo Racing quality
Each Koyo Radiator is custom built OEM fitment
Koyo Radiator cap is not included, (Aftermarket Radiator cap is needed for installation)
Mishimoto Radiators uses high quality aluminum and is hand-welded to give you an experience of superior craftsmanship. One of the better aspects of these radiators is the use of specially designed brass fittings to ensure 100% leak proofing from the outlet to the overflow reservoir. In fact, leakage is a major problem with most radiators. These radiators are approved only after pressure-testing them twice. The ultra-strength of billet aluminum fill neck is another highlight of these radiators.
Mishimoto Radiators are better than any of your regular OEM radiators with 20%-25% more heat dissipation abilities. If you are thinking about an aftermarket setup, then radiator should be your first priority. The demand for an aluminum radiator is more acute if you are running your car hard. This is because of more heat produced by hard usage of car, which can be effectively handled only by a good quality aluminum radiator.
HankYee
Aug 14, 2009 12:58 PM
Superhatch
24
Sep 20, 2004 10:13 AM
oddcivic
Feb 6, 2002 12:17 PM
GTEater
Aug 30, 2001 03:36 PM
