Stock ground wires location help.
Old Nov 21, 2008 | 01:04 PM
Silentz's Avatar
Default Stock ground wires location help.
where can i locate them on my 1992 Accord? I have no clue where they are located.
thanks for the help.
Old Nov 21, 2008 | 03:00 PM
Duane_in_Japan's Avatar
Is something not working, there are many ground wire locations, did I say many.
Old Nov 21, 2008 | 07:37 PM
Silentz's Avatar
i need the one from the tranny to the body and another one bolt to the tranny or the motor in the wiring harness.
i got the above info from a distant friend.
Old Nov 22, 2008 | 10:21 AM
I would say the bolt that goes from the tranny into the motor, pull one out where ever this ground wire large round terminal will reach and put the bolt through it and rescrew it though the tranny bell housing back into the motor.
The ground from the tranny to the body is sometimes called a bonding wire, you can install one anywhere you wish from the tranny to the body.
Theoretically, the engine and transmission are isolated from the rest of the chassis and body and electrical system because they are mounted to the car with engine mounts and transmission mount that are made of rubber so the engine and tranny are insulated from the electrical system and require a ground wire to tie (or bond) the engine and tranny to the electrical system. Another purpose of the bonding wire is to dissipate static electricity in an attempt to lessen corrosion due to electrolysis due to the motion of fluids inside the engine and tranny, the same goes for the cooling system.
Old Nov 23, 2008 | 07:37 PM
Silentz's Avatar
thanks for the explaination, but i need the location of these two wires. Can you help?
the explanation gave me the general idea of how it works.
thanks
Old Nov 25, 2008 | 12:15 AM
I can understand that the bonding wire is missing but the ground wire that gets bolted onto the bell housing, so you are saying you cannot find one, its been cut, its not there at all. Forget about looking for these things, make your own bonding wires, thats it.
Unless you know where the ground wire to the bell housing is supposed to go or where is it coming from, what is it grounding, a little more help please.
slow94ej1
May 17, 2013 02:12 PM
jdm_boy.1
Jun 2, 2010 06:46 PM
hatchback_al
Feb 12, 2004 10:30 PM
euclid
Oct 31, 2003 01:06 PM
