Can someone please tell me how long thier Integra GSR dip stick is
Old Nov 21, 2008 | 06:29 AM
white4doorsi's Avatar
Default Can someone please tell me how long thier Integra GSR dip stick is
I recently purchased a gsr swap. When i got it home i noticed it didnt have a dip stick so i went back and the seller gave me the one he believed came off of the motor. The problem is i only see oil readings when i do oil changes. I dont have any visible oil leaks and my car doesn't blow out any smoke at all.
So im beginning to think i have the wrong dipstick. Can someone measure their dip stick and tell me how long it is. Ill have to order on from Acura if the dipstick is the problem. Thanks
Old Nov 21, 2008 | 06:39 AM
K i l l a B e e.'s Avatar
all dip stick are the same ls/gsr/itr
Old Nov 21, 2008 | 07:21 AM
Are you sure about that? If that was the case could you put an LS oil pan on a GSR?? I thought a LS dipstick was shorter. Ill try to find an LS dip stick at the junk yard
Old Nov 21, 2008 | 07:26 AM
the vtec oil pan is different due to oil pick up. A dipstick measures depth and b series use the same amount of oil.
Old Nov 21, 2008 | 07:27 AM
Ok well ill try it. Im gonna go to the junkyard today. thanks man
Old Nov 21, 2008 | 07:30 AM
yeah the reason be is because i just finished swapping in my car yesterday and was adding oil. After 4 qts i pulled the dipstick and i didnt see any oil. First glance i thought my dipstick might be the wrong size, so i compared mine (gsr) to an LS and they were identical. Then i realized that my oil was reading on the dipstick, it was just clear! I've never had a freshly built block =P.
Old Nov 21, 2008 | 11:30 AM
nsxtasy's Avatar
H-T Order of Merit
That's correct. It's part number 15650-P30-000 for all '94-01 Integras.
turboman2.2
Apr 21, 2010 03:46 PM
hondaracer13
Jun 2, 2008 01:42 AM
Sic_DA_Nine
Apr 29, 2006 06:40 PM
2 point 0
Dec 24, 2004 12:59 PM
DIRep972
Sep 22, 2001 11:06 AM
