idle screw?!
Old Nov 21, 2008 | 01:02 AM
ptown909's Avatar
Default idle screw?!
where is it at!?!?!?
i need some pictures cause my car is driving me nutz with the idle problem
Old Nov 21, 2008 | 04:33 AM
Dogginator's Avatar
Daisy... Daisy...
I don't have a picture. It is on the top front (front of car) of the throttle body. You need to have the car fully warm, shut off all accessories, and disconect the IACV to adjust the idle to 450+-50 RPM.
Old Nov 21, 2008 | 09:48 AM
zccivic94's Avatar
not to thread jack...but do you keep the car on the whole time you adjust this? ^^^
Old Nov 21, 2008 | 12:15 PM
zccivic94's Avatar
bump
Old Nov 21, 2008 | 12:49 PM
super jdm yo's Avatar
yeah you keep your car running
Old Nov 22, 2008 | 10:05 AM
DC626's Avatar
Like stated above , it is located on the throttle body next to where the intake connects to. And there's a screw you twist after you unplug the iacv . Its fairly simple and you should be able 2 adjust it with a simple flathead screwdriver.
Old Nov 22, 2008 | 10:25 AM
racebum's Avatar
the car needs to be fully warmed up for you to have any chance at this, just to reinforce dog's post. i mean drive 10 miles and come home, turn the car off. unhook the idle control valve, start the car, feather the gas so it stays running if needed. once it catches an idle do your adjustment. if you can borrow a scan tool they are really helpful since you can watch the exact rpm while you turn the screw.
Iloveyourhonda92
Apr 11, 2015 07:46 PM
dirtyharryhatch
Dec 14, 2011 05:45 PM
skata89
Jun 3, 2006 12:58 PM
fe519
Nov 21, 2002 05:58 PM
