95 Accord Wagon Question
Old Nov 20, 2008 | 08:15 PM
civicdelsol33's Avatar
Default 95 Accord Wagon Question
To pop the lower ball joint apart from the front LCA, can I use the square socket wrench trick like on the 95 Civic? gotta change two axles and was curious.
Old Nov 20, 2008 | 08:18 PM
TheMuffinMan's Avatar
He knows where you live!
Whether its the correct way or not I took my largest ratchet and popped it out. Then lifted up on it and moved it to the side
Old Nov 20, 2008 | 08:25 PM
Confusion. Is that a go on the jack up the knuckle, put a square wrench between the knuckle and the LCA, let jack down and pop?
Old Nov 20, 2008 | 08:29 PM
Should work, I pushed up on the knuckle with both thighs to swing it out with the ratchet in there to pry the arm and ball joint apart.
Old Nov 21, 2008 | 12:41 AM
slammed4thgen's Avatar
take bfh and beat the lca with it till it pops loose
shouldnt take much
just incase...bfh=big ducking hammer
ducking with an f in the place of the d
HONDAPARTSMANMIKE
17
Sep 29, 2010 04:14 PM
Digitalsmoke
Aug 14, 2009 08:57 PM
89turboteg
Feb 22, 2007 08:55 AM
Slow_import
Jan 19, 2006 12:25 AM
tom991
Mar 30, 2004 04:40 AM
