anybody knows what this gold thread is?
Old Nov 20, 2008 | 07:27 PM
choua01's Avatar
Default anybody knows what this gold thread is?
I bought this engine and it's missing this piece so I went and bought this gold piece from home depot and plug it in. does anybody knows if this will work on my B16a2?. thanks a bunch guys.
Old Nov 21, 2008 | 08:29 AM
choua01's Avatar
bump
Old Nov 21, 2008 | 08:43 AM
lsvtecturbosol's Avatar
not positive what you are asking but as long as what you put in there has a hole for it to breathe into that black box then yes you should be fine.
Old Nov 21, 2008 | 11:51 AM
b16_sol_707's Avatar
you should be fine the way it is.
Old Nov 21, 2008 | 12:02 PM
Paul-R's Avatar
thread lock is needed i used this on my old swap and it will leak with no thread lock plumbers thread lock works good .
Old Nov 21, 2008 | 02:34 PM
pdiggitydogg's Avatar
...you mean brass...
You got it in there, so it will work. You probably jacked up the original threads, since the part you got is npt, block is likely metric (doubtful, but bspt is the alt thread).
The stock nipple isnt anything special...youre fine, assuming you used some rtv on the threads
car-toons
May 13, 2005 02:05 PM
civicdx1
Oct 17, 2004 06:36 PM
BlueR
May 30, 2002 01:05 PM
