HELP! How To Wire Crank Angle Sensor to OBD0 ECU?
Old Nov 20, 2008 | 06:28 PM
i_VTEC's Avatar
Icon2 HELP! How To Wire Crank Angle Sensor to OBD0 ECU?
Hello there Honda-Tech. I had a question for a friend of mine. He wanted to know how to wire his crank angle sensor to his 96 b20b motor which is in his CRX. Its an OBD0 LS ECU. I tried to look for another thread on honda-tech but i couldn't find any. If you have any idea, Your input would be greatly appreciated. Thanks again Honda-Tech!
Old Nov 20, 2008 | 10:34 PM
D16SiHatch's Avatar
I assume by crank angle sensor you mean the CKF Crank Fluctuation Sensor?
does it look somethin like this?
If thats it, you don't need to worry about hooking it up. the obd0 ecu does not use nor have an input for a ckf sensor.
