camber kits
Old Nov 20, 2008 | 06:11 PM
dboy06types's Avatar
Default camber kits
is there a specific type of camber kit i should get? or are they all about the same?
Old Nov 20, 2008 | 06:46 PM
hawaiiancb74's Avatar
all about the same, ingalls is the only one piece unit all the others are welded i would go with the ingals or spc
Old Nov 20, 2008 | 08:03 PM
ejLday's Avatar
I got the spc it does the job but will rust. ingals is nicer depends on how much you wanna shell out...
Old Nov 21, 2008 | 06:24 AM
ok so i went with ingals with the polyurethane bushings... it says they need to be lubricated properly or they will squeak... so my question now is what kind of lube????
Old Nov 21, 2008 | 10:34 AM
archull's Avatar
use that marine teflon grease because it is waterproof and you will not have to re-apply it later down the road. The trick it to let the poly stay lubbed and wet. When it dries out is when it squeaks.
If I were you I would probably get the rubber bushings instead of the poly. The poly is going to ride rougher and it is noisey compared to the rubber bushings which are made for a street car. The poly inserts are really made for race use
Old Nov 22, 2008 | 12:21 AM
yeah get rubber
Old Nov 24, 2008 | 07:42 PM
ejLday's Avatar
if lubed properly he will be fine plus poly will last a lot longer than rubber
Old Nov 24, 2008 | 10:54 PM
yes but u have to lube them periodicly, thats the only differance but for a non racing application who wants to do that.
Old Nov 26, 2008 | 12:13 PM
i went with rubber since its my daily driver.....now im jus waitin for everything to get here
Old Nov 26, 2008 | 07:23 PM
ejLday's Avatar
whether it's for racing or not poly lasts longer, and you don't have to lube them that often. Bottom line is they will hold up longer than rubber hawaii
Old Nov 26, 2008 | 09:00 PM
yeah i know that.. and i have to lube mine or they make noise just like my progress rear sway
Old Nov 26, 2008 | 09:59 PM
square_1's Avatar
I use KY Jelly.... Oh wait... Yeah, stick with the marine grease. I will probably get some bushings on my car poly (the ones that are easy to access to lube) and others just regular rubber.
KCUF_DB8
Suspension & Brakes
Feb 23, 2010 05:30 AM
Acura_DreamiN
Jun 12, 2009 04:19 PM
MugenPoweredLude
Feb 10, 2003 05:35 PM
Jowee
Dec 11, 2002 12:51 PM
vteg
May 10, 2002 07:04 PM
