will p28/obd1 harness work on b20
Old Nov 20, 2008 | 04:23 PM
iheartmyctr's Avatar
Default will p28/obd1 harness work on b20
the title pretty much somes it up want to know even if i just get the jumper harness will the p28 run the b20
Old Nov 20, 2008 | 05:40 PM
93turbo16's Avatar
If the P28 is chipped then yes. All you have to do is have someone burn a B20 map for you.
If it isn't chipped then get someone to chip it for you. You don't want to run a B20 on stock P28 maps.
Old Nov 20, 2008 | 05:53 PM
yes its got s200 type r map right now so it needs to be reburned.......
Old Nov 20, 2008 | 05:58 PM
93turbo16's Avatar
Then the ecu will be just fine.
Just have someone put a B20 map on it for you.
Kea
Nov 21, 2018 02:32 PM
kevinEJ
Nov 16, 2012 01:20 PM
TAZ95
Nov 20, 2010 09:50 AM
dansXR2
Mar 10, 2010 08:36 PM
edgarespinoza
Feb 14, 2007 11:26 PM
