Which fuel pump to use?
I have a b20vtec. It has JE pistons in it, and it is in a 92 cx. I was told that my fuel pump is too small. I only have a couple hundred mile on it, so far, so I haven't gunned it all the way yet. What fuel pump should I change to? Would a GSR one be good enough? Also would a B&M fpr be good too? TIA
it might be a little bit of an overkill, but, i would go with the Bosch fuel pump. nice sized and it can support up to 600 hp at the fly.
Walbro 255 high output is what i will be using from here http://www.autoperformanceengineering.com/
extremely good and quick service
yea, get a b&m fpr too
I'm just using the fuel pump off of a turbo DSM. I heard it was good to 350hp. Works fine so far, and I got two of them for like $40. But then again, I'm not running high hp or anything, so...
