cam gear adjustment
Old Jul 31, 2002 | 07:16 PM
LB CRX's Avatar
Default cam gear adjustment
lets say i have a b16 w/ctr cams and a milled head.....would it work better with the intake gear (+) degress and the exhaust gear (-) degrees, or the other way around?
i took off my gears and now i dont know there they were supposed to go...setting them back to zero will screw with the tuning i just paid for. can we say STUPID THINGS HAPPEN TO STUPID PEOPLE? TIA
Old Jan 3, 2003 | 03:21 AM
visi0n's Avatar
Default Re: cam gear adjustment (LB CRX)
since you milled your head you can only tell what will make best power on the dyno. you also should degree your cams when your engine is out since its easier. A qualified engine builder should be able to degree your cams easily.
MotorSpecies ver1.6
10
Nov 29, 2007 04:26 PM
urgonnalearn2
Nov 8, 2004 12:32 PM
Seye
Mar 10, 2004 03:32 PM
All Motor EG
May 28, 2002 01:15 PM
