Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
BUDDY CLUB SUSPENSION SUPER DUPER SALE!
Old Nov 20, 2008 | 12:03 PM
velocitytrends's Avatar
Default Buddy club suspension super duper sale!
Please PM me, AIM me at VelocityTrends1, email me at vtrends@velocitytrends.com, or call me at the shop at 904.997.9903 for the HONDA-TECH PRICE! Ask for the NEWEST PROMO CODE!
You can also click here to purchase at our store.
http://www.velocity-trends.com/
We are now offering a sale on all Buddy Club suspension products!
The first option is the N+ Spec Dampers!
"N+ SPEC DAMPER" from Buddy Club is the choice complete suspension setup with resemblance of our RACING SPEC damper's excellent attributes. It is cost effective and is well rounded for the budget minded weekend club racer. With optional urethane isolated aluminum upper mount design, engineered spring rates, 15 level damper adjustability, and ride height adjustment capabilities, the N+ SPEC DAMPER can accommodate any driver's preferences.
They offer:
1. Ride-Height Adjustable
2. 15 Level Adjustment
Suspension adjustability is a key element when selecting a top quality coil-over system. The N+ SPEC DAMPERS are designed to accommodate a wide range of driving conditions from regular roads to prepared racing surfaces. Dampening settings ranges from hard (+4kg/mm) to soft (-4kg/mm).
3. Mono-Tube Type Shell Case
The shock-body is constructed out of cadmium plated steel and is finished with beautifully anodized precision CNC machined aluminum ends. Urethane bushings are used when applicable to ensure a top quality product.
4. Great Quality Finish
To ensure that the N+ SPEC Dampers stay looking superb through your years and years of ownership, each precision CNC machined aluminum component is beautifully burgandy anodized and each steel component is cadmium plated for corrosion resistance. Great attention to detail was taken to ensure that you will be completely satisfied with your ownership of Buddy Club components.
They are available for the following vehicles:
Acura
Integra (DC2, Type R)
TSX
RSX (DC5)
Honda
S2000
Civic Si (EP3)
Civic (EG6)
Civic (EK9)
For the Integra (DC2, Type R), Civic (EG6), and Civic (EK9) upper mounts are an available option for an additional amount.
The second option is the Racing Spec Dampers!
"Racing Spec Damper" is the perfect complete suspension kit with resemblance of P-1 racing damper's excellent designs while it is de-tuned for street - circuit use. However, the car specific pillow-ball upper mount design, proper spring rate, 15 level damper adjustment, and height adjustment capabilities accommodates driver's requests
They offer:
1. Adjustment Bracket
With an adoption of a "adjustable bracket" the ideal low postion can be achieved without any use of helper spring. One rotation, approximately 2mm, will enable the user to change the length of the damper. Dampers are black plated rather then painted for extra durability.
The 15 level adjustment corresponds to variety of racing stages, from Touge 'mountain roads' to cicuits. Adjustment is easy with its click adjusting dial. The dial is located ither on the upper shaft for regular dampers or on the lower shaft for inverted dampers. This damper is also designed for town use; hence, dampening setting ranges from hard (+4kg/mm) to soft (-4kg/mm).
3. Single Tube Type Shell Case
Unlike visual based cartridge damper, adoption of the single tube shell case enables the use of wishbone type 46 and strut type 36. This leaves an extra space for larger pistons. Also this change allows for better heat dissapation, which prevents performance deterioration from hard runs. Special steel and anti-friction components are used to minimize friction.
4. Specialized Pillow-Upper Mount
Application of the upper pillow upper mount allows you to have greater handling response, by minimizing upper chasis movement. Caster adjusment allows the correction of camber for further tuning ability. Caster adjustment plates are not included on all applications.
5. Spring Seat / Lock Seat
Each single full rotation equals 2mm drop. The adjusting locking seat allows for spring stress to adjust with out the necessity to change suspension position.
Acura
NSX (NA1/2)
TSX
RSX (DC5)
Honda
Accord (CF4)
Civic (EF9)
Civic (EG6)
Civic (EK4/9)
Civic (EP3)
CR-X (EF8)
Prelude (BB1/4)
S200 (AP1/2)
For the Integra (DC2, Type R), Civic (EG6), Civic (EK9), and S2000 (AP1/2) upper mounts are an available option for an additional amount.
Don't forget, whenever lowering a vehicle it is recommended to run a camber kit. Luckily Buddy Club offers their own so we can put together a combo package for you!
The Buddy Club camber kits is a little different from all the other camber kits available. By using low profile joints they offer 5mm more clearance between the top of the kit and the bottom of the strut tower.
The P1-Racing Camber Kit is available for the following vehicles.
Acura
Honda
Civic (EG6)
Civic (EK9)
Old Nov 21, 2008 | 10:15 AM
All Pm's replied. Thanks!
Old Nov 24, 2008 | 12:42 PM
Still On special HT! Thanks!
Old Nov 25, 2008 | 07:28 AM
TTT!
Old Nov 25, 2008 | 03:03 PM
Buddy Club Ready To Ship!
Old Nov 26, 2008 | 06:53 AM
Buddy Club suspension x-mas gift to yourself! Woot Woot!
Old Nov 26, 2008 | 09:56 AM
junktea1's Avatar
Default buddy club coils
how much for a set shipped to 91206 - this is for a 08' honda fit
Old Nov 28, 2008 | 07:20 AM
All PM's and post replied thanks.
Old Dec 1, 2008 | 05:38 AM
All pricing includes shipping!
Old Dec 1, 2008 | 08:30 AM
We have been here this long for a reason! Buy with confidence!
Old Dec 3, 2008 | 05:22 AM
TTT
Old Dec 4, 2008 | 07:09 AM
All Pm's and E-mails replied thank Guys and Gals.
Old Dec 6, 2008 | 01:56 PM
Bump!
Old Dec 9, 2008 | 08:40 AM
Back up top!
Old Dec 10, 2008 | 10:02 AM
blk92_d16's Avatar
I am in the market for a Racing Spec Damper set for my '92 EG chassis. Please send me via PM your price shipped to 29617.
Thx!
Old Dec 10, 2008 | 10:46 AM
blk92_d16's Avatar
Thx!
Could you also quote me on the N+, just in case that Racing set is too much for me right now.
Thx!
Old Dec 12, 2008 | 09:13 PM
pkdog167's Avatar
Price for 94-01 Integra non-type-r N+ spec no pillow mount shipped to 94015, Thanks!
Old Dec 13, 2008 | 09:39 AM
All Pm's and E-mails Replied thanks!
Old Dec 17, 2008 | 06:01 AM
Up Up and away!
Old Dec 17, 2008 | 07:20 AM
ONEdotEIGHt-T's Avatar
Price for EG N+ spec shipped to 98444?
Old Dec 22, 2008 | 04:14 AM
Default Re: BUDDY CLUB SUSPENSION SUPER DUPER SALE!
Almost X-mas bump!
Old Dec 23, 2008 | 06:22 PM
all pm's replied!
Old Jan 3, 2009 | 07:39 AM
Happy New Year HT!
Old Jan 12, 2009 | 07:32 AM
Back to the top! Great Prices.
Old Jan 13, 2009 | 06:45 AM
