96-00 civic wiring harness ... swap-able?
Old Nov 20, 2008 | 12:03 PM
integra321's Avatar
Default 96-00 civic wiring harness ... swap-able?
i realize the 96-00 civic engine harness is one piece from the motor to the ecu but what i was wondering is if it removable/changable? my friend has a 99 civic dx and he is going to be putting in a b16 from a 2000 civic si. his harness is pretty messed up so we were wondering if it is possible to change the one piece harness with a harness from the civic si?
Old Nov 20, 2008 | 12:08 PM
Justin4's Avatar
yes you can use a harness from an si
Old Nov 20, 2008 | 12:09 PM
integra321's Avatar
do you know how to remove it? annd is it hard?
Old Nov 20, 2008 | 12:34 PM
jnyceone's Avatar
its alot easier to just cut and splice from the Si harness to yours. Just look for the truobled areas on ur harness and take em from the si
Old Nov 20, 2008 | 01:16 PM
94EG8's Avatar
Seagull Management
Unplug it from the ECU and underdash harness, there are 2 bolts or nuts on studs, remove them and pull the harness through the firewall. Its not hard at all.
No, its actually a lot easier to just remove the whole harness.
BlendedEM1
Feb 13, 2011 07:06 PM
bradennicely
Apr 25, 2010 04:36 PM
91H4hatch
Sep 8, 2006 08:14 PM
v-tec maz
Jan 8, 2006 07:01 PM
Crimson_Tide
Jun 30, 2005 12:23 PM
