rapid click in main relay.
Old Nov 20, 2008 | 10:40 AM
99EeeKay's Avatar
Default rapid click in main relay.
heres the deal. cars a 91 ef hatch. motor blew. so a DOHC obd1 zc was put in its place. the car was converted to obd1 and all that jazz... however now when we put teh key in and ignition to the on position. the main relay clicks a bagillion times a second. and the starter wont turn the motor.
any ideas of what could be wrong?
Old Nov 20, 2008 | 11:34 AM
91dxsedan's Avatar
recheck your wires maybe one not getting a good conection causeing the relay to freak
Old Nov 20, 2008 | 12:29 PM
Perfectionist's Avatar
Ussually a sign of a weak (dead) battery or poor connections.
Old Nov 20, 2008 | 12:42 PM
GUNMETALREX's Avatar
I had the same problem when i did my first swap and it was the ground coming from the ecu to the main relay i would doube check of the grounds and then check the conversion to odb1 make sure all you ecu connections.
Old Nov 20, 2008 | 12:43 PM
Crx Jimmy's Avatar
Icon3
I had that exact problem when the burned chip in the ecu was bad. Swapped ecu's and it went away
Old Nov 20, 2008 | 01:09 PM
traxxasx's Avatar
check ur ecu fuse under the hood.
Old Nov 20, 2008 | 03:19 PM
biggee's Avatar
This is common...my car has done this. Remove your Tstat ground, even if it looks tight and fine, and clean it thoroughly.
Old Nov 20, 2008 | 03:22 PM
allgo88's Avatar
+1
Old Nov 20, 2008 | 04:32 PM
Nerologic's Avatar
Old Nov 20, 2008 | 05:57 PM
99EeeKay's Avatar
thanks for the response.
we figured it out. aparently. the engine grounds were forgotten about :doh:
RMXmitch
Nov 1, 2007 03:46 PM
white90rexsi
10
Jun 28, 2007 02:50 PM
freshly boosted DOHC ZC
Apr 6, 2007 06:41 PM
itr1244
Jun 23, 2006 05:57 PM
