Wiring Vtec
i need a diagram or something one wiring vtec into the strut tower harness, i have a 92 civic cx hatch so i know its already prewired from the strut harness to the ecu, i need to know where to pin in all the wires at on the engine harness. any help would def be apreciated
some people just go from the orange/white(vtec wire on chassis) and just hot wire it straight to the vtec solenoid, or the wire's for it.
but, since you have a 92, it should just be plug and play as long as the engine is a obd1
the engine is obd1, the engine harness is not wired for vtec, so i need to wire it for vtec, and i need to know where to pin the wires in at, i have the clips for the solenoid and what not, i just need to know where to pin the wires into the strut tower plugs
This should help you out. Oranage/white goes to green/yellow and orange/blue goes to blue/black, the black wire from the green vtec pressure switch is a ground, ground it to something.
Jakester9500
12
Aug 8, 2007 05:25 AM
92EG8
11
Nov 17, 2006 08:50 PM
lightningd
Apr 4, 2003 01:30 PM
