AGX settings.
Old Jul 31, 2002 | 06:41 PM
YaMaJeSty's Avatar
Default AGX settings.
i juss got my kyb agx in from the infamous inline4.com! i got H&R race springs with them. juss wonderin wut settings on the AGX's do you guys have them on and how does it ride for race and for driving. please indicate wut kind of springs u have as well. thanks guys!
Old Jul 31, 2002 | 09:23 PM
deepnite's Avatar
Default Re: AGX settings. (YaMaJeSty)
ive got them on with my eibach pros..#1 setting is stock #2 is 15% stiffer, 3# is 50% stiffer than #2..im emailing u the the other info dude
Old Jul 31, 2002 | 09:56 PM
YaMaJeSty's Avatar
Default Re: AGX settings. (deepnite)
dude, this is exactly wut i was looking for! thanks dude! this is exactly everthing i wanted to know. you are the man! thanks dude!
Old Aug 1, 2002 | 07:46 AM
TKBLAZER's Avatar
i drive around with them all on #3
Old Aug 1, 2002 | 10:24 AM
Doctor CorteZ's Avatar
2F / 4R
on custom rated ground controls.....
Old Aug 1, 2002 | 01:08 PM
dogpile5's Avatar
25 Year Member
Default Re: AGX settings. (TKBLAZER)
same here. i also added the ITR rear sway...gets a tad squirrely in the rain
Old Aug 1, 2002 | 03:34 PM
phatcivic99's Avatar
Default Re: AGX settings. (dogpile5)
3f/6r...on ground controls. i love my set up i think it is not to stiff and not to soft. good for on/off ramps and on hilly roads.
Old Aug 1, 2002 | 06:46 PM
broke1's Avatar
Default Re: AGX settings. (phatcivic99)
3/6 with h&r race springs
Old Aug 1, 2002 | 11:55 PM
YaMaJeSty's Avatar
Default Re: AGX settings. (broke1)
how does your car ride? i have the same setup goin on. i also have an ITR rear sway coming in with some srr lca's to top off the suspension. itr srr
Old Aug 2, 2002 | 07:55 AM
atisvt99's Avatar
Someone told me I should put the Integra Ground Controls on my coupe if I planned on doing a swap in near future... something about the spring rate being more forgiving of a dohc motor??? All I know is the ride is pretty harsh. I've got my AGX's set to 1 all the way around and I still think I'm riding around on cut springs from time to time... Any ideas? Should I get a set of civic G/C's and make it right? thanks
Old Aug 2, 2002 | 09:00 AM
Mojo-Jojo's Avatar
Hey, can we get the rest of that progression? Or can you email it to me?
Thanks.
Old Aug 2, 2002 | 09:07 AM
IM ALL BOB's Avatar
Default Re: AGX settings. (atisvt99)
Atis you can get any Spring rate You want from GC.. if You order directly from them they will get you the setup you would need unlike most other Companies that only carry 4 or 5 spring rates.. Ground control orders directly from Eibach and they carry any Spring rate you need
Old Aug 2, 2002 | 09:21 AM
deepnite's Avatar
Default Re: AGX settings. (Mojo-Jojo)
info on the way...since fwd cars a heavier its suggest d that the front struts be adjust d bit tighter..say the rears are set at 2..the front should be at 3 or 4..rears at 3, the front should be at 4 or 5..any more for of road only
Old Aug 2, 2002 | 09:41 AM
atisvt99's Avatar
Default Re: AGX settings. (IMALLBOB)
alright... welp, as stock spring rates go then, I ordered the G/C kit for a late model integra... I've got a not-to-late-late model civic. Are the teg rates that much stiffer? any idea?
Old Aug 2, 2002 | 11:51 AM
deepnite's Avatar
ive uve got a civic..why are u ordering springs for a teg? excuse me but did i miss something?
fiebru1119
Mar 26, 2006 02:48 PM
daewonder.
May 13, 2003 09:14 AM
94acurals
Sep 25, 2002 11:55 PM
far
Jan 16, 2002 07:24 PM
InfamousRS
Oct 21, 2001 03:06 PM
