Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
R18 Oil change oil filters from b18c?
Old Nov 19, 2008 | 05:19 PM
Rikaro's Avatar
Default R18 Oil change oil filters from b18c?
I have some B18C hamp oil filters. Do they fit into the R18?
Old Nov 19, 2008 | 05:20 PM
MessGSR's Avatar
i am almost positive they are all the same thread....u should be fine..
Old Nov 19, 2008 | 05:27 PM
Rikaro's Avatar
I know that the D-series, B-series uses the same. The K uses a different one so I was wondering if the R18 has a different one.
Old Nov 19, 2008 | 07:24 PM
guinnessstout's Avatar
my honda dealer uses the same filters on the r18 that they use on the v-6 and older civics, fits, crvs, andaccords the only filters that are different are the insight and the
s2000.
Old Nov 20, 2008 | 11:37 AM
E-Money's Avatar
you want the A02 filter
Old Nov 20, 2008 | 11:39 AM
SIVIC 3's Avatar
they will fit. honda uses pretty much 1 filter for ALL models. excluding s2000 and some older sub-90's models.
Old Nov 20, 2008 | 11:42 AM
pd0019's Avatar
yea...you should be fine.
Old Nov 20, 2008 | 11:49 AM
Rikaro's Avatar
sweet thanks guys
So the K-series uses the same too? it's funny how I mistaken this
Old Nov 20, 2008 | 03:25 PM
SIVIC 3's Avatar
yes. K-B-D-R = same filter
Old Nov 20, 2008 | 04:31 PM
vladd's Avatar
are they exactly the same size and everything? i noticed that the k&n filters for the gsr and the 06+ si have different part numbers.
Old Nov 20, 2008 | 05:00 PM
ekb16's Avatar
honda has like 3 diff. size filters..the s2k filter is the biggest(fat) one, the insight is a small short one and the middle size one is wut we use the most...last i heard the small insight oil filters were discontinued..u can sub the A02 filters for the insight and the s2k
here is a pic of a reg. middle size filter and the honda inside filter
Old Nov 21, 2008 | 09:36 AM
98PAITR's Avatar
s2000.
There are only two filter sizes now. Honda put out a bulliten to use the normal filter on the insight. So only the S2000 gets a different filter.
frankie11
Sep 2, 2007 01:54 PM
vlballa
May 7, 2007 04:58 AM
coronadrinker
Oct 14, 2006 02:45 PM
lowlavar
Sep 11, 2006 07:27 PM
stevescivic
19
Jun 28, 2005 02:50 PM
