replacing engine block with tranny still in
ok so i'm trying to replace my d series with another d series engine. my axle nut is rusted on the rotor or axle and i tried everything to take that off but it didn't work so f that.
so i was wondering if i can just take out the engine block and leave the transmission in their, is their anything i need to watch out for ...
car is a 2000 civic dx
From: New York in the summer, South Carolina in the winter
Bad idea man- are you sure you unstaked the nut?
Worst case scenario, if it still runs take it to a shop, have them blast it off, and then put it back on, drive home and then do the swap-
but again, unstake it,
spray penetrating oil on it, hammer it for 2 minutes, spray again and repeat that about 10 times, then get a torch heat it up, and it should pop right off- there is no reason it wont pop off with a decent breaker bar, or a impact
GL!
GL!
I did it once without removing the transmission. It was the worst idea ever. I had a problem with a badly damaged axle nut that would not come off. I removed the caliper and rotor and just unbolted the upper and lower control arms and took it all off as an assembly. it was MUCH MUCH easier then leaving the transmission in.
i dont even think there is enough room for the clutch/flywheel to clear with the tranny in the car is it? just spray the hell out of the nut with pb blaster get a good breaker bar and go at it.
I had a case where I COULD NOT get the crank pulley off. (motor was on a stand, it would just spin the crank) It simply would not go- my dad was a tech for years, so we were using all quality tools, a IR 1/2" and it would not go- tried heat, PB spray, that stuff that you spray and it is super cold, and quite a few other things-
Ended up pulling the head, fabbing up a piston stopper that utilized the head bolts, and with a huge breaker bar, finally came-
Point is, no matter what you can ALWAYS get a bolt out-
OP use heat its your friend
Why do people remove the axle from the hub when they are not changing to a different style axle or to replace the axle is beyond me!
Do this:
Break lower ball joint free from LCA.
Keep BJ off LCA and pry axle from diff.
Once axle isn't locked into the diff anymore, you can remove the lower fork bolt.
Swing the hub assembly, with axle attached, out of the lower fork and let it hang to the ground. It is clear of the transmission and the axle nut never needs to be removed.
Do this:
Mark D. Surface
Oct 24, 2007 03:34 PM
Aphelion
Apr 25, 2005 04:18 PM
rasinhell
Jan 13, 2005 09:52 PM
mrxracing
Apr 29, 2004 03:04 PM
