98 Accord power windows and door lock problems
98 Accord LX 4 door, all 4 windows work off their own switches and drivers side rear will work off drivers master switch but front and rear pass. side windows do not work off drivers master switch, also the power door locks do not work,
Yes, I have checked all the fuses, switches and connections, all are good.
AllData suggests that the problem is the drivers side multiplex control module, [in drivers door master switch assembly, replaced it, still have the same problem. 94
I agree with AllData, The left side (drivers) Multiplex Module.
It is NOT (however) incorporated in the Master Switch Assembly.
Refer #11
... and the associated Web link:
http://www.hondaautomotiveparts.com/...IT+%28CABIN%29
P
Refer #11
P
I wondered about that, the pass. side multiplex control module is attatched to the back of pass fuse box, ALLDATA indicates it is in the master switch and our Honda dealer agreed and sent us the master window switch assemble, it did not solve the problem.
The dealer also sent us a "used/returned" unit, we assumed it was also bad, I am going to love calling the dealer and tell them the multiplex control module is not in the master switch assembly and when they send the correct part, make sure it is new.
BTW, thanks.94
BTW, thanks.94
carve
Oct 6, 2009 02:44 PM
mgerdes
Oct 23, 2005 06:25 PM
