Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
How to tune shocks?
Old Jul 31, 2002 | 04:58 PM
yoshi234's Avatar
I shoot brides
Default How to tune shocks?
Whether it be Koni, Mugen (showa), or any other type of adjustable shocks. I'm sure it comes down to preference, but what is the best way to find the correct dampening for a given damper?
yshi - whose tempted to go the Bilstein/GC route to K.I.S.S
Old Jul 31, 2002 | 05:15 PM
NegativeLift's Avatar
Default Re: How to tune shocks? (yoshi234)
shock speed histogram...if you have the $$ for data acquisition
otherwise, i dont know!
Old Aug 1, 2002 | 09:36 AM
ITR764's Avatar
werd . all that adjustabilty is just too much info for me right now.
Tyson's Avatar
lap times.
Old Aug 1, 2002 | 09:52 AM
RR98ITR's Avatar
Yoshi,
It's hard to beat buying something that somebody else has used successfully. And by successfully I mean somebody who goes fast - really fast - in the same car.
Don't be too put off by adjustable shocks in general. Buying any decent single adjustable makes good sense when you haven't gone all the way with rates and you want simple but effective adjustability.
The most basic damper adjustment instructions are Koni's as quoted by Carroll Smith - they are widely available and simple to follow.
Scott, who thinks that if you keep it simple and do it well you can go faster than guys who make it complicated and do it poorly....
Old Aug 1, 2002 | 09:55 AM
Tyson's Avatar
Default Re: How to tune shocks? (RR98ITR)
that book was made over 20 years ago...
Old Aug 1, 2002 | 10:30 AM
RR98ITR's Avatar
Default Re: How to tune shocks? (Tyson)
Koni still publishes the same procedure. What about it is invalid?
Scott, who reminds you that Yoshi want's to keep it simple....
Old Aug 1, 2002 | 10:45 AM
SJR's Avatar
SJR
while I am definitely an expert, or a racer for that matter, here is what I did to adjust my Konis for the _street_ (a setup that proved adequate for HPDEs)
After installing the shocks and springs, I took a SWAG as to where I thought the settings should be. This swag was made as follows:
the Konis should be good until about 600lb (depending on who you ask, blah blah - it was my starting point) and I was using about 400lb springs for the front so I set the fronts above 2/3 stiff. Similarly I set the rear a bit over 1/2 stiff (using 350 lb springs). The idea was to slightly over-damp the suspension.
Took out the car, went over a few bumps at moderate speeds and noticed that indeed the suspension was a little slow rebounding. So I lightened up the setttings and repeated the cycle until the suspension started bouncing when hitting bumps (moving in small increments - around 1/8 turn each time). At that point, I went back to the previous setting and called it critically damped.
That's what I use for the street, and I am happy with it.
If I knew more about suspensions, I might want to change my settings, but at least I know where the neutral point is for each end. Now, I will know how to make the suspension over or under damped, at will - again, if I ever think that i need to do so, and understand why.
I hope this was simple enough, even though I may not have explained it in the most succinct way.
Tyson's Avatar
oh, youre talking about the adjustment procedure. thought you were referring to carrol smiths adament advice on going with koni. because while koni does make quality products, the advice is antiquitated, and fairly irrelevent to street and sedan products as they make em different for formula suspensions.
Old Aug 1, 2002 | 11:00 AM
Philbert's Avatar
Default Re: How to tune shocks? (SJR)
how do you like the 400/350 setup in your integra? i am currently running 350/250, and don't feel it is uncomfortable... it was suggested i move the front springs to the back and go stiffer in front. just curious as to your impressions...
Old Aug 1, 2002 | 12:11 PM
SJR's Avatar
SJR
Default Re: How to tune shocks? (Philbert)
off-topic, you've got IM
iNtoXicaTedSPOON
Jan 19, 2004 12:01 PM
ACR
Apr 25, 2003 01:41 AM
1ofAkindGSR
Oct 29, 2002 08:53 AM
SIK IN DA HED
Feb 20, 2002 09:14 PM
balistic CRX
Jan 5, 2002 09:09 AM
