help please
Old Nov 19, 2008 | 11:56 AM
crxhani's Avatar
Icon6 help please
hey guys i have d15b turbo on crx i have a heavy traction problem please help ? should i got LSD and wide tires ? and any information about traction bar for crx ?
Old Nov 19, 2008 | 05:07 PM
EFRue57's Avatar
more details are needed before any good advice can be given. what tires are you running now, brand and size, what suspension are you running, what rpm's are you launching at, how much power are you making? a lot of aspects need to be accounted for before you can put the problem to one solution. if you're making high hp numbers but have crappy tires then that is one solution. if you have good tires but you're launching at 7k rpms then no amount of tires or lsd is going to help you. if you have crappy suspension then when you launch your car there could be a lot of weight transfer to the rear, lifting your front end and that could keep you from getting traction to the ground. so again give us some more details of your car and that can help us point you in the right direction.
bobafreaklx
Mar 11, 2007 06:47 PM
ALLBOOST
Jul 9, 2004 03:02 AM
CaptainMorgan
Mar 7, 2004 11:13 PM
GetawayInMoscow
Aug 21, 2002 03:57 PM
quikrpm'z
Sep 9, 2001 12:52 PM
