ignition issues
Old Nov 19, 2008 | 11:45 AM
MaVx's Avatar
Default ignition issues
I bought the civic a little while ago, it needed a new lock cylinder, previous owner ripped out the cylinder and broke the housing; i bought an entire steering column and installed it last night.
this is the weird part:
the ignition acts like its 1 position behind. at posistion 0 obviously nothing, position(acc) 1 is nothing also, position(run) 2 the radio comes on nothing else and position(start) 3 the clock and blower comes on but no starter.
im lost... anyone have an idea?
Old Nov 19, 2008 | 11:50 AM
Yuen001's Avatar
hey there, are you sure you have the right part ? and is it wired correctly ? sounds like the wires are mixed up
Old Nov 19, 2008 | 12:04 PM
MaVx's Avatar
wires dont get messed up when they are simply plugged in. yeah its the right part.
the same issue happened when a screwdriver was used as a key on the old column, i had to turn the position to 3 and arc the starter.
Old Nov 19, 2008 | 12:47 PM
Yuen001's Avatar
i haven't taken apart an ignition cylinder in a while, but if i remember correctly, there is a lock pin on the key cylinder that pops through a small hole in the key cylinder housing.
what this does is makes sure that you can't turn the key cylinder if there is no key. make sure that these are lined up because i think that is the only locating feature on the key cylinder.
i had a similar problem where the key wouldn't turn all the way, until i lined those up
let me know if this helps
Eastd914
Feb 6, 2013 07:40 AM
ekkscott
Honda Civic (2001 - 2005)
Jun 6, 2012 02:45 PM
BxBomber712
Feb 5, 2010 11:39 AM
donut.
17
Jan 11, 2010 07:03 AM
Studiox1
Feb 5, 2007 11:17 PM
