opinions on heat wrapping intakes
Ive seen it done a couple of times before but wasn't sure if it was really worth it to do. Obviously its going to help keep intake temps down initially, but once the intake gets up to temp will it have a lot harder time cooling down with the wrap on?
It also of course depends on the material of the pipe. Heat wrap typically assumes "metal" (typically aluminum), but plastic aftermarket intake systems for our cars do exist.
I don't know where I'm going with this. Back to bed.
(I think I'm trying to say it'd be about equivalent to the heat-dissipation properties of a plastic intake pipe.)
Heat wrap helps to trap heat in... I don't know why people think that it is a good idea to wrap anything but exhaust in it. It is good for exhaust because it helps the heat from radiating out into the e-bay and in FI apps, more heat=thermal efficiency=faster spool time... Anyways this is what you want:
http://store.summitracing.com/partde...5&autoview=sku
