Get your quality used parts here. 92-95 Civic & More.
Keep in mind I have alot more parts than you see pictured.
And please be polite and bump the thread for me.
If you bump the thread and buy something from me I will cover the paypal fees.
[B]I got a low milage 1998 H22 VTEC COMPLETE TOP END for sale.
Head with valves
Looks rusty in pics but it is not. Will take more photos if you need them.
H22 FUEL RAIL
H22 ENGINE HARNESS
H22 INTAKE MANIFOLD
From a 98 prelude
In the meantime feel free to contact me with your civic needs.
You can also text or call me at 662-305-5000 up until 3 am.
Thank you.
2000 Si inner door handles with good lock tabs.
Virgin p28 ecu Manual Transmission 125.00 shipped.
Several ignition switches...Wiring and lock cyls with O.E.M Honda keys.
95 Passenger Air Bag (BLACK).
96 Integra Tilt Column.
96 Integra Ignition switch with OEM key.
96 Integra black steering wheel.
96 Integra SRS Clockspring.
96 Integra cruise control buttons.
96-00 Tilt Steering Column.
Plus much much more.
E.Honda
Head with valves
H22 FUEL RAIL
H22 ENGINE HARNESS
H22 INTAKE MANIFOLD
From a 98 prelude
Thank you.
E.Honda
01-02 CIVIC TILT STEERING COLUMN
92-95 CIVIC TILT STEERING COLUMN
92-95 CIVIC STANDARD STEERING COLUMN
STEERING COLUMN JOINT
01-02 CIVIC IGNITION SWITCH w/ KEY and WIRELESS REMOTE
UNDER DASH TRIM
Grey
UNDER DASH TRIM
Black
BLACK INNER HANDLE TRIM.
FUSE ACCESS DOOR
Black
FACTORY AIR FILTER BOX
Filter Included
POWER MIRROR
Right Side - 2 door and Hatch
MAIN RELAY
STOCK D SERIES INJECTORS
$8.00 each shipped
LEFT FOG LIGHT EG. Lense busted. Bracket good light is prob good.
UNDERHOOD FUSE ASSORTMENT
AIR BAG SRS REEL CLOCK SPRING
Removed from a 2001 civic
WIPER SWITCH FOR 96-00 (EK) HATCH w REAR WIPER
I also have one for the 2 and 4 door.
D SERIES POWER STEERING BRACKET
92-95 CIVIC SUNROOF RELAYS
D SERIES VTEC
AUTO TRANSMISSION FLYWHEEL BOLT
HOOD/TRUNK RUBBER ADJUSTERS-STOPPERS
94-95 EG AIRBAG HARNESS
92-95 EG CENTER DASH VENT
BLACK 01 CIVIC STEERING WHEEL
Minty clean
92-95 STEERING WHEEL BROWN
92-95 AIRBAG BROWN
96-00 IGNITION HARNESS
96-00 IGNITION SWITCH WITH KEY
92-95 UNDERHOOD FUSE BOX COVER
CLUTCH RESEVOIR and BRACKET
GREY EBRAKE BOOT
SUNROOF RELAYS
POWDER COATED TOW HOOKS
96-00 INNER DOOR HANDLES
From 2000 civic Si Minty clean
REAR PLATE TRIM PANEL
LEFT SIDE HATCH TAIL WITH BULBS AND HARNESS
Have a full set from 4 door sedan
UNDER DASH TRIM
Grey
UNDER DASH TRIM
Black
FUSE ACCESS DOOR
Black
Filter Included
POWER MIRROR
MAIN RELAY
$8.00 each shipped
D SERIES VTEC
Minty clean
92-95 AIRBAG BROWN
GREY EBRAKE BOOT
SUNROOF RELAYS
Minty clean
92-95 AIRBAG BROWN
GREY EBRAKE BOOT
SUNROOF RELAYS
Minty clean
92-95 AIRBAG BROWN
GREY EBRAKE BOOT
SUNROOF RELAYS
