2000 Civic- Bad O2 Sensor, possible exhaust manifold issue
"Check Engine" came on a while ago and was told by dealer that O2 sensor was bad. I've waited to replace it because they also told me that in trying to replace it, the exhaust manifold might be damaged, taking the total cost from $350 to $1170. This seems ridiculously expensive to me, and I'm concerned that I might not be getting the most accurate information. Does anyone have advice? Should I take it elsewhere or is this typical?
Thanks!
Thanks!
Thanks!
Thanks!
Thanks!
Thanks!
If you are confident in your own ability and have tools, you could do it yourself for the cost of the oxygen sensor (assuming a DX or LX, you can pick up an NTK replacement sensor for around $70) and an oxygen sensor socket. Just keep in mind that you will be SOL if you pull the threads out of the manifold.
I see damaged O2 sensor threads all of the time out of virgin engines. I'm going on a hunch and assuming it's not an EX, and has the cat in the manifold. This creates so much heat that the manifolds almost always crack along the O2 sensor threads.
If your manifold is damaged, it should be covered by the 8/80 warranty, if you're under 80k
It is illegal for a business to sell a used catalytic converter; most salvage yards won't do it unless you have "connections." The price that Honda quoted him was almost certainly for the D16Y7 manifold with integrated cat.
mrwokn
Mar 20, 2011 08:44 AM
Fighterinsnatch
Apr 29, 2007 11:20 AM
