flashing battery light
That's technically the charging system warning light. Do not continue to run the car, since you will run down the battery to dead, and every time a battery is driven to dead shortens its life even after a jump.
Check the alternator belt tension first. If loose, tighten.
Use the five simple checks of the charging system given about 1/3 of the way down at http://honda.lioness.googlepages.com...alternatortips to figure out what to do next.
wing.jai
13
Dec 29, 2013 05:29 PM
