speedometer jumpy, loss of power. Itr swap
Old Nov 18, 2008 | 06:44 PM
julian_gq's Avatar
Icon2 speedometer jumpy, loss of power. Itr swap
HI everyone, I have recently got my car swapped and bar'd in cali. But recently I have noticed when I get on the car the speedometer jumps around a bit and goes dead, than usually is followed by the car bogging and acting sporadic. IF anyone knows anything or has any ideas, I will greatly be in your debt.
a little info about the car. Integra gsr shell, jdm itr motor jdm ecu , jdm gauge cluster.
thank you.
Old Nov 18, 2008 | 06:50 PM
teg_95's Avatar
my friend had the same problem. does you odometer work. of not try replacing the speed sensor
Old Nov 18, 2008 | 07:43 PM
julian_gq's Avatar
I don't know if the odometer works, i will check first thing tomorrow.
Old Nov 18, 2008 | 07:51 PM
95DC2GS-R's Avatar
Sounds like the speed sensor, but the car bogging and such, I have no clue..
I'm not fimilar with the JDM components, but do they have CEL's? Try getting the codes pulled.
Old Nov 19, 2008 | 05:27 AM
teg_95's Avatar
also does your vtec open? my friend vtec didnt open because of a bad speed sensor.
Old Nov 19, 2008 | 06:51 AM
weavertime1's Avatar
Check the ground on your thermostat housing...I have seen this issue a few times...any CELs? Could also be related to a distributor issue. Good luck!
Old Dec 3, 2008 | 01:26 PM
julian_gq's Avatar
yea the vtec opens just fine just fine. I think what happens the speedometer drops off and the vtec needs the speedometer to work. than the bogging starts happening.
Old Dec 3, 2008 | 01:28 PM
julian_gq's Avatar
so bad distributor could cause this? with the jdm ecu there are no codes. and i will check the ground on the thermostat housing, thanks a lot for all these great ideas.
Old Dec 3, 2008 | 01:56 PM
00geezer00's Avatar
vtec doesn't run off of the speedo, it runs off of oil pressure and rpm's. When the conditions are met the ecu will engage vtec.
HRubss
Jul 30, 2016 03:55 PM
freakasis
Apr 25, 2006 06:04 PM
PaisanITR
Mar 4, 2006 11:17 AM
Trev-R
Aug 23, 2004 12:26 AM
Integ_TypeT
Aug 27, 2003 05:33 PM
