Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
'04 Accord - high-pitched whine when backing up
Old Nov 18, 2008 | 04:07 PM
JerseyGirl474's Avatar
Icon2 '04 Accord - high-pitched whine when backing up
Hoping someone here can help me figure out what's wrong with my car ... I have an '04 Accord EX, and whenever I go in reverse without using either pedal, the car makes a high-pitched whining sound (not squeaking); the sound is coming from the rear of the car. Can anyone tell me why this is happening?
Thanx!
Old Nov 18, 2008 | 06:35 PM
chinochanginc's Avatar
wheel bearing?
Old Nov 19, 2008 | 04:43 AM
impound's Avatar
rear pads
Old Nov 19, 2008 | 04:59 AM
But wouldn't it make that noise when the car is going forward also if it were the pads?
Old Nov 19, 2008 | 10:09 AM
6poundsdaily's Avatar
is this your first honda? they all whine in reverse
Old Nov 19, 2008 | 12:48 PM
impound's Avatar
it will soon enough.
Old Nov 19, 2008 | 12:51 PM
impound's Avatar
it will soon enough. just my opinion. if i could see it i could tell you for sure.
Old Nov 19, 2008 | 01:16 PM
No, it's my second - had a 2000 Civic before this car - and that one NEVER made this noise (or any noise in reverse, for that matter), and I've had the Accord for a year and it only started making this noise a week ago.
Old Nov 19, 2008 | 01:31 PM
LittleRat's Avatar
New User
Try jacking the car up and rotate each rear wheel individually to see IF its just one side or the other. Then I'd take the caliper off to see if it is a bearing, as was previously stated. I'd replace the pads anyway....especially the way they drive in Pennsyl-Jersey.
Old Nov 19, 2008 | 02:02 PM
MustangLX6.0's Avatar
Not on the rear, espically on that accord if your backing up and hear a loud high pitched noise then you have a pad on the indicator. Wheel bearings dont make high pitch noise the noise is more like a droning type tire noise at highway speeds
Old Nov 19, 2008 | 02:30 PM
1grex's Avatar
Rear brake pads
Old Jan 24, 2013 | 11:10 AM
pmlawrence's Avatar
Default Re: '04 Accord - high-pitched whine when backing up
I also have an 04 Honda Accord EX V6 that has just started making this whining noise when I back up. I do not have my foot on the brakes when it happens so I am baffled by what it might be. Has anyone else found out what the problem is? Thanks.
Old Feb 4, 2013 | 09:05 AM
bladi3990's Avatar
a whimning gear noise is normal in reverse. a groaning noise isnt normal.
Posted from Honda-tech.com App for Android
Old Feb 19, 2013 | 09:22 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
My Accord only made a high-pitched noise in reverse when a rear caliper was seized. And that is a VERY common issue with these cars.
bigjoncoop
Mar 12, 2018 05:06 PM
willowcairns
12
Oct 6, 2013 05:50 PM
StickyOut
Aug 15, 2013 02:48 AM
hondaracer4vtec
Aug 19, 2008 07:43 AM
richmojm
Jun 27, 2005 10:02 PM
