1998 Honda Accord Coupe.
Could anyone tell me how to remove the passenger side exterior door handle? I have the door panel off, the two 10mm bolts holding the handle on removed, the key less entry connector removed from the locking mechanism, the window guide removed, and the thing still will not come off! The only thing still connected is the rod running from the top of the door handle to the door latch, because I do not know how to remove that without being able to see it. The outer door handle will not budge at all, and I have no idea what is holding it on, any ideas guys?
Just guessing, get a good flashlight in there and see if there is another bracket, with a 10mm or smaller bolt or screw, clamping the handle assy to the door skin. Just look at another rod plastic retainer to get an idea how to just swivel that little latch off of the rod, they are all the same, it may be blue or green or pink or whatever.
Did you do a search or check the how to / diy area?
Scott Younker
May 28, 2019 07:33 PM
Sfgiant87
Nov 1, 2008 08:12 PM
