NEPA..EM1Parts/Mugen TL/ LsVtec Swap/B-series/EK Parts. Gotta GO.
Old Nov 18, 2008 | 02:41 PM
cbk0485's Avatar
Default NEPA..EM1Parts/Mugen TL/ LsVtec Swap/B-series/EK Parts. Gotta GO.
Recently crashed my FBP 2000 Civic SI i am parting out the whole thing.Car has front end damage so NO LIP. There are lots of other random items from my Ek hatch as well. Most of the good items are already gone. I am located in allentown, PA. Prefer local pick-up. I have paypal and a bunch of vouchs so id be willing to ship smaller items.
STILL MORE TO ADD. EMAIL ME AT CBK0485@GMAIL.COM..... NO
TRADES,UNLESS FOR KSERIES PARTS.
Ls Vtec swap for 96-00 civic
SOLD SOLD SOLD SOLD SOLD SOLD
B16A2 Head,B18B1 Block with a polished S4C trans mission no grinds or popouts. Newer OEM clutch. Inside is all stock other than ARP headstubs and cosmetic stock size headgasket.
New Timing Belt, water pump, oil pump and tensioner. Mfactory sandwich plate.AEM alt. Pulley.New starter. Password cam seal. ITR valve cover MSD plug wires.alt bracket has been drilled and tapped for knock sensor.
comes with
Axles, shift linkages, throttle cable, vibration mounts, rear&side trans bracket, P2T ecu, rad hoses, and oem header,
motor runs very strong only was only put together about 5k ago. EMAIL ME with any questions.
JHPUSA Exculsive Black Hasport mounts 96-00 civic. Rear trans mount and side trans mount $110 apiece.
GONE TO BUCKNASTY
Complete Mugen Twin Loop Exhaust system for EK9. 675 picked up
96-98 OEM headlights like new. GONE TO BUCKNASTY
2000 SI Rear Seats 2 small cig burns in cushion. Uppers are mint. $55
Tanabe axle back exhaust. Small hole in axle section. $30
2000 Civic Si OEM B-pipe. SOLD
2000 SI Armrest SOLD
CTR Shift Boot
SOLD TO Mikeycivic
FBP Power Mirrors $45 for pair has scratches on inside near window from someone trying to break in easy fix with touch paint.
FBP surrounding has small crack in it mesh is mint. $35
SOLD TO Seek167
Matrix racing front strut bar SOLD
Door tweeters $45
2000 SI Prop valve SOLD
B16 Ac Compressor SOLD
B16 power steering pump with brackets SOLD
Driver. side Panel is gone. Still have passenger side with switch.
96-00 Civic HB DX Wing VSM Mint. $50
JDM EK9 Civic Type R Cluster. Dont wanna sell, but i will for $350 no less. If you can get it for less than go ahead.
SOLD bucknasty
96 spec ITR wheels and suspension
SOLD to Duongbros.
Spoon duracon shift **** black. SOLD
B&M short throw shifter SOLD
96/98 to OBD1 Ecu jumper harness $65
Datum 1 rear tow hook black SOLD
00 SI Rear sway Bar Complete. $45
CD7 JDM Honda Access air refiner $125
01 JDM ITR Front Brake Lines $30
JDM ITR Cat. $115
Greddy Radiator Cap. $10
B16A2 Pistons and Rods SOLD.
2000 B16A Starter OEM. SOLD to Midori
2000 B16A Half Shaft $35
2000 B16A IACV SOLD
2000 B16A Alt. $40
B16A2 Ac Bracket $35
2000 Civic SI Pass. Side Vibration Mount $20
2000 SI rear t bracket SOLD
Random 2000 Civic SI Parts
Make Offer.
Fuel Line x2
throttle cable
Sunroof assembley
Crusie control complete unit
Battery Tray {black}
Evap canister complete
Hood,trunk,fuel door release cables
Crowl{mint}
5 speed pedal assembley
Brake booster and master cylinder.
Clutch slave with res.
Front upper control arms
Misc plastic trim pieces.
E Brake handle
Rear view mirror
Rear decklid brake light
Steering column plastic SOLD
Primary O2 sensors x2{denso}
Power mirror switch
Power mirror relay
Lower steering knuckle cover
Driver side vent
Fuel pump assembley
Front speaker covers
Cabin fuse box
Dimmer switchs x2
Main Relay
Random Bseries stuff.
0bd 1 P75 SOLD
0bd2a P75
Header heat shields x2
Crank pulley
Breather Box
Upper/lower Alt. Brackets
Dipstick
Ek driver side two post mount
Header Bracket
Clutch cover
Obd 1 Ls Throttle body
B16a2 Fuel Rail
B16 Intake Mani. Bracket
Random EK stuff.
2000 Civic Passenger Headlight $30
Type F light grey Pass. Airbag
00 Ex Pass. Lower front control arm SOLD
00 Ex front sway bar w/ links SOLD
Rear wiper motor
Non painted driver side mirror manual
Fuel tank sending unit
Shift ****
Driver side mount new {autozone}
Old Nov 19, 2008 | 12:40 AM
buckNasty's Avatar
have some k stuff in my for sale and have a wtb thread, check em out and lmk
Old Nov 19, 2008 | 03:40 AM
cbk0485's Avatar
Thanks ill check it out bump
Old Nov 19, 2008 | 12:12 PM
cbk0485's Avatar
Bump
Old Nov 19, 2008 | 04:55 PM
gATOr65's Avatar
how much for the driver side engine bracket for a b16
Old Nov 19, 2008 | 05:36 PM
buckNasty's Avatar
pmd replied
Old Nov 19, 2008 | 07:08 PM
cbk0485's Avatar
You need the two post the attached to the block?
Old Nov 19, 2008 | 10:05 PM
gATOr65's Avatar
yea, the .post mount
Old Nov 20, 2008 | 04:45 AM
cbk0485's Avatar
Bump
Old Nov 20, 2008 | 11:07 AM
cbk0485's Avatar
TTT
Old Nov 21, 2008 | 03:39 PM
00blkSi's Avatar
was the si passenger front lca salvagable? don't really want a 2 piece from an ex... and what about the climate control bezel, don't need the controls!!
Old Nov 21, 2008 | 04:12 PM
mikeycivic's Avatar
bump for meh homie, seen this POLISHED tranny in person and its one of a kind and looks great. GLWS Matt
Old Nov 22, 2008 | 09:05 AM
cbk0485's Avatar
Sorry sold the whole front sway and lca swap. And the whole 00 climate control stuff is gone.
Old Nov 22, 2008 | 09:11 AM
cbk0485's Avatar
Thanks homie, yeah I got to get some better pics of it. Polishing the new tranny now, Its a bitch.
Old Nov 22, 2008 | 09:30 AM
CivicEX13's Avatar
i know it says no front lip but is it damaged that bad?
Old Nov 24, 2008 | 05:31 AM
cbk0485's Avatar
Yeah it was thrown away.
Old Nov 24, 2008 | 05:26 PM
owa's Avatar
owa
do you happen to have the radio brackets that hold down the climate control bezel? feel free to pm if you do
Old Nov 24, 2008 | 06:05 PM
lostsol82's Avatar
pm'd
Old Nov 25, 2008 | 08:08 AM
cbk0485's Avatar
Originally Posted by lostsol82
pm'd
PM replied
Old Nov 25, 2008 | 06:50 PM
88aeFC3S's Avatar
pm sent
Old Nov 25, 2008 | 08:07 PM
cbk0485's Avatar
Originally Posted by 88aeFC3S
pm sent
Replied
Old Nov 28, 2008 | 09:45 AM
cbk0485's Avatar
BUMP
Old Nov 28, 2008 | 10:01 AM
unified112's Avatar
Happen to have the upper B16 Powersteering mount/bracket? Mounts to the head with two 14mm bolts. If so, what are you looking to get for it?
Old Nov 29, 2008 | 07:17 PM
ridetrials's Avatar
willing to ship the mugen twin loop to vancouver canada? please email me at ridetrials@hotmail.com
Old Dec 2, 2008 | 07:09 AM
cbk0485's Avatar
Sorry sold....
