F/S: 1996 INTEGRA DB7 (MILD-BUILT)
Old Nov 18, 2008 | 12:36 PM
pooorman's type-r's Avatar
Default F/S: 1996 INTEGRA DB7 (MILD-BUILT)
EDIT: PRICE DROP 5500. CAR WILL COME WITH STEELIES AND NO ALARM.
ALSO OPEN FOR TRADE, PARTIAL TRADE WITH 1500-2000 cash (your side), depending on your car.
THE CAR IS A 96 ACURA INTEGRA GS (SPECIAL EDITION). THE BODY HAS 172,XXX. MOTOR HAS 6,XXX. CLEAN TITLE (NO ACCIDENT, EVER!), POWER EVERYTHING! GREAT HEAT FOR THE WINTER. A/C NEEDS TO BE RECHARGE. THERE'S NO RUST ON THE BODY. THE CAR HAS BEEN GREAT TO ME SINCE 2004. I'M THE 2ND OWNER. 1ST OWNER WAS AN ELDERLY COUPLE IN ILLINIOS. THIS CAR HAS NEVER LEFT ME HANGING. ONLY SELLING CAUSE I GOT A NEW CAR. THIS IS MY DAILY DRIVEN CAR TOO. I STILL DRIVE IT SO THE MILEAGE WILL BE HIGHER THAN POSTED, DEPENDING ON HOW LONG IT TAKE TO SELL THE CAR. THE VEHICLE IS ALSO EQUIPPED WITH A VIPER 2-WAY PAGER ALARM W/ REMOTE START.
THE EXTERIOR HAS DENTS AND DING FROM DAILY DRIVEN, NOTHING MAJOR. NEVER BEEN INTO ANY ACCIDENT. THE CAR ALSO HAS THE 98+ FRONT END W/ A REPLICA TYPE-R LIP. THE CAR WILL COME WITH STEELIES OR SLIPS (DEPENDING ON PRICE!)
INTERIOR IS CLEAN FOR IT'S AGE. IT HAS GREY LEATHER INTERIOR. NO RIPS, CLEAN JUST SOME COLOR CRACKS. THE BACK SEATS ARE MINT!!!
THE MOTOR HAS 6XXX MILES ON IT ONLY. IT'S CLEAN, NO OIL LEAKS, DOESNT BURN ANY OIL. HAS NEW GASKETS ALL AROUND! OIL PUMP, WATER PUMP, TIMING BELT, ETC. ALWAYS OIL CHANGE WITH CASTROL FULLY SNYTHETIC 5W-30 EVERY 2500-3000 MILES. THE MOTOR HAS BEEN TUNE FOR DAILY DRIVEN. IT GETS 30-31 MPG CITY/ 34-35 HWY. GREAT GAS MILEAGE.
THE MOTOR SPECS. ARE:
MOTOR:
95 GSR BLOCK 81MM - GSR RODS W/ ARP ROD BOLT, PR3 PISTONS, NEW CLEARANCE ACL MAIN, RODS, AND THRUST BEARING, HASTING PISTON RINGS, ARP HEAD STUDS, BUDDY CLUB HEAD GASKET (COMPRESSION RATIO IS 11:7:1)
99 B16 HEAD W/ MILD INTAKE PORT AND POLISHED, GSR TB AND SKUNK2 IM, ITR VALVE TRAIN, GSR CAMSHAFT, JDM ITR 4-1 HEADER STYLE, TEST PIPE, 2.5 MID-PIPE TO STOCK MUFFLER
STOCK 95 GSR TRANNY W/ 120ISH K (NO GRINDS OR POP OUT), ACT STAGE 1 CLUTCH, STOCK ITR FLYWHEEL, SKUNK2 SHORT SHIFTER
WITH SOME HIGHER LIFT CAMSHAFT, THIS MOTOR WILL EASILY MAKE 200+ WHP WITH A GOOD TUNE!
SUSPENSION:
TOKICO ILLUMAS W/ OMNI COILOVER (6XXX MILES)
GSR FRONT AND REAR SWAY BAR
ENERGY BUSHINGS
ENGINE MANAGEMENT:
OBD2A TO OBD1 HARNESS CONVERTED
CHIPPED P28 W/ TUNE BASEMAP
PRETTY SURE I'M MISSING SOME OTHER INFO. BUT IF YOU GOT ANY QUESTION PM ME OR CALL ME AT 414-426-0333. PRICE IS 6000 OBO
HERE'S SOME PICS OF THE CAR, THE CAR HAS THE 98+ FRONT END W/ ITR REPLICA LIP:
Also, ONLY TRADE I'LL TAKE IS 98+ GSR!
Edit: added motor pic.
Old Nov 18, 2008 | 04:22 PM
dlee9's Avatar
bump for a nicee db7
Old Nov 19, 2008 | 03:18 PM
TTT
Old Nov 20, 2008 | 08:51 PM
upupupupupupupupupup
CPreston
Acura TL, RL & ZDX
Mar 12, 2010 02:31 PM
asocallocal
Jan 25, 2010 08:09 AM
pooorman's type-r
Dec 18, 2008 11:41 AM
NguyenDC2
Oct 29, 2007 06:24 PM
