Turn signal switch not working
Old Nov 18, 2008 | 11:32 AM
Shocka1998LX's Avatar
Default Turn signal switch not working
When I flip the turn signal to left or right, the signal does not display on the gauge cluster nor does it turn on the actual turn signal itself. So is there something wrong with the switch on the steering column?
When I hit the hazard button, it turns on all turn signals as well as lighting up the gauge cluster. So this rules out a blown fuse for instrument panel and turn signal.
I was installing new climate control bulbs and everything went fine until I ran into this. Everything is plugged back in... except for the 12v outlet and my radio.
Old Nov 18, 2008 | 12:00 PM
shake-zula's Avatar
make sure you check everything including your fuses....cause if you turn the signal to turn on and none of the lights light up it might be the switch itself.....make sure thou, i made the mistake and ending buying a brand new switch which i didnt need lol....my problem was with my harness
Old Nov 18, 2008 | 12:50 PM
Yeah I solved the problem. Had to do with the hazard switch. Ignore this thread.
Meraut
Mar 11, 2013 06:34 AM
smmagoo20
Nov 6, 2012 07:59 PM
egboy94
Feb 26, 2011 05:52 AM
urtz
Lighting
Aug 23, 2009 06:49 PM
92eg_b16
Oct 19, 2008 12:52 AM
