EF9 SIR Seat Swap
Old Nov 18, 2008 | 09:51 AM
xalents23's Avatar
Default EF9 SIR Seat Swap
Wanted to know if, anyone of you guys out there know how to swap these seats in a 1991 CRX SI. I have tried the seat pan swap and it does not work. The seat pan does not line up properly to the EF9 seat. Any info would be greatly appreciated.
Old Nov 18, 2008 | 12:05 PM
hushypushy's Avatar
I think the idea with the seat pan swap is that you are supposed to modify the seat (in this case, the EF9 bottom) to fit the pan (the CRX).
In other words, you have to cut the foam.
Old Nov 18, 2008 | 03:56 PM
xalents23's Avatar
Even if I cut the foam the seat will not line up. The part where the allen key screw on the side of the seat is off by 3 inches. Even if I cut the foam it will not align the seat properly.
Old Nov 18, 2008 | 04:19 PM
crxmadness's Avatar
You are also supposed to use the crx reclining mechanism along with the seat pan. Remove the EF9 reclining mechanism and install the crx one with the crx seat pan.
Rice For Dinner
Jan 31, 2012 07:02 PM
quirarte626
May 6, 2009 08:40 PM
flowda
Apr 13, 2008 12:37 AM
FBPSidan
14
Oct 12, 2005 10:47 AM
0ptimus prime
Jul 26, 2005 08:39 AM
